Thread: 2004 GT2-ABS comes on when not needed **help**
Results 1 to 3 of 3
  1. #1 2004 GT2-ABS comes on when not needed **help**
    Wyoming
    I have a 2004 Pontiac Grand Prix. For the last month my ABS comes on when I don't need it to come on-no bad weather, no ice on the streets etc. The ABS/trac control and system engine lights come on probably every couple of days but when I turn the car off they go away. My husband changed the brake pad, brakes feel better but the ABS is still coming on when I try to stop. Could it be a mechanical sensor or something else??
  2. #2 Re: 2004 GT2-ABS comes on when not needed **help**
    St. Louis Mo.
    Moved to correct section.
    James Shafer
    St. Louis MO
  3. #3 Re: 2004 GT2-ABS comes on when not needed **help**
    New Brunswick
    It sounds like a bad speedsensor/wheel hub assembly but the first place to start would be to find someone with a code reader that is able to read abs codes to see what this tells you instead of trying parts one by one.
  1. Opinion Needed....
    By Bgerk in forum Tires & Wheels
    Last Post: 07-13-2009, 01:58 PM
  2. 2004 lincoln Lsv8 or 2004 GP GTP?
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-10-2009, 03:58 PM
  3. help needed imediatly!
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2009, 12:51 AM
