Hey everyone,
My abs light is on, and the check tire pressure light is on.
I have a laundry list of ABS codes stored...
Current Code:
C1232 Left Front Open
History Codes:
C1221 Left Front speed zero
C1225 Left Excessive variation
C1232 Left Front open
C1257 Left Front short to ground
C1263 Right Front motor short to ground
C1265 Right Front motor short to battery
C1291 Rear Motor short to ground
C1293 Open brake switch during deceleration
I recently purchased the car with 175k on it. I plan on replacing both front rotors, pad, and obviously the left front hub assembly if I can't find an open circuit. Should I worry about the history codes, and will disconnecting the battery reset them if/when I replace the one hub?
Thanks in advance
