Has anyone repaced inner tie rods on a 1999 GP?
I have replaced both ball joints, driver side outer tie rod, both front wheel hub assy's, sway bar and sway bar links, now I need to change the passenger side inner tie rod. Can it be replaced while on the car or do you have to remove the steeering assembly? My Haynes book says nothing about the inner tie rod.
Thanks in advance.
