Thread: inner tie rods
Results 1 to 20 of 21
  1. #1 Re: inner tie rods
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Quote Originally Posted by Iron Indian View Post
    This white plastic cap, its on a knuckle, Which one? is it at the joint? Do you reuse it?
    Thanks...
    Shawn, the white cap covered the area where the tool would slide over, it's about 1.5 inches long, when you remove the rubber boot you'll see it.
    I just took a screw driver and lightly tapped it back (slides back towards the rack). You then see the machined part that the tool would slide over, after replacing the inner tie rod I just slide the cap back over it again.
    Once you get the rubber boot off, it will become alot more easier to see what I'm referring to.
  2. #2 Re: inner tie rods
    Moore, Oklahoma
    Quote Originally Posted by BlownBigBlock View Post
    I assume you need a back up wrench right? Did you need to measure anything with a feeler gauge?
    Shawn W. Larsen
  3. #3 Re: inner tie rods
    Apr 2009
    Carlisle PA
    What is this back up wrench you refer to??? To put the inner tie rod back on you use the same tool you used to remove it. And I didn't use
    any feeler gauge for anything.
    With the variances between manufactures, I just went stop to stop on the steering wheel, set it at halfway and put everything back together.
    I'll adjust it closer when it comes time for the alignment.
  4. #4 Re: inner tie rods
    SE Level Member hondo's Avatar
    Salt Lake City, Utah
    im doing my inner passenger and i cant get the boot off its supposed to have a threded clamp but mine doesnt have one. its just solid. do i cut it?
