Thread: inner tie rods
Results 1 to 20 of 21
  1. #1 Re: inner tie rods
    SE Level Member MichEE's Avatar
    Aug 2008
    Michigan
    Quote Originally Posted by grreed View Post
    Everything went good after Autozone got me the right tool. I did mess up the large band for the boot, but a hose clamp worked fine. I also had to replace the outer tie rod end. The bolt had a hex head on the end that broke my 8mm socket and then stripped out. Had to cut it off. This sure was better than having to take the whole rack out.
    Thanks again!!
    Thanks for the post and comments. I am going to try and do mine this weekend. What was the 8mm socket for? Any other "special" tools needed? I am also doing my ball joint, control arm bushing and sway bar (if I can find one!!).
  2. #2 Re: inner tie rods
    Wichita, KS
    Thats good news to hear.
    Always helps to see the replacement part, and the special tool needed before you start the job, that way you can see whats going to go where and what or how it comes out of your car.
    Visual aid FTW!
    ~F~
