Tin plate that mounts the wheel abs sensors wiring connector can also rub the rotor causing an inferiorating intermitant brake squeal. plate rubs rotors after a brake application, inturn causing the rotor to expand from generated heat ever so slightly. resulting in an intermitant squeak or squeal that is not present with cold brakes. sorry about the novel. Hope this helps
