Thread: Using Computer to Activate ABS Module?
Results 1 to 5 of 5
  1. #1 Using Computer to Activate ABS Module?
    Aug 2017
    Detroit
    I recently acquired a '03 Grand Prix and I'm looking to flush the brakes. I'd like to cycle the ABS pump to do a complete fluid change. I know the correct way to do this is to use the GM Tech-II scan tool but I'm wondering if its possible to do this using a laptop computer? Seems like there should be some sort of program that will allow you to do this, kinda like engine tuning that people already do through laptops.
  2. #2 Re: Using Computer to Activate ABS Module?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Easy way is to flush, bleed, take out on a gravel road and force a few ABS stops, then bleed again. 98% as effective as cycling the ABS pump with a scan tool.
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  3. #3 Re: Using Computer to Activate ABS Module?
    Unless you have some special program that can control any module, you won't be able to do it with a laptop.
  4. #4 Re: Using Computer to Activate ABS Module?
    Aug 2017
    Detroit
    Ok thats what I figured. Why don't they make a program that can be put on any computer to do the same thing as a scan tool? The whole concept of scan tools is stupid in the age of computers and most techs have laptops in their toolboxes now a days.
  5. #5 Re: Using Computer to Activate ABS Module?
    Some car makers do have laptop based scan tool systems with a dongle for doing diag on cars. Mercedes, VW/Audi/Lambo's, BMW and several others do but the programs are either not available to the public or are stupid expensive.
  1. Radio with Theftlock--How to Activate
    By bocoogto in forum Audio, Security & Visual Electronics
    Last Post: 09-18-2017, 02:41 PM
  2. "Connecting to activate.tapatalk.com..."
    By J7319M in forum Forum Bugs/Suggestions
    Last Post: 04-25-2017, 07:21 AM
  3. CAI and the computer
    By BigTom73 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 07:57 PM
  4. Do I need to activate Perf. Shift in stock pcm for it to be enabled?
    By Freebeer187 in forum General Tech Discussion
    Last Post: 10-18-2008, 04:27 PM
