Thread: Need some help with new rear rotors/calipers
Results 1 to 13 of 13
  1. #1 Need some help with new rear rotors/calipers
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    Ok, so today i installed new Acdelco Ready struts along with powerstop calipers and centric rotors on the rear of my 01 GT.
    Everything went fairly smoothly, except i noticed the drivers side rotor seems to be extremely hard to get it over the parking brake. Old one came off with a little tap of the mallet.
    Upon test driving i noticed that the car would not coast forward from a stop when the brake was released....also had a loader squeal when in reverse.
    Any suggestions? Do i need to adjust the parking brake so that rotor slides on more easily?
    Thanks!!
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  2. #2 Re: Need some help with new rear rotors/calipers
    sadly the best way it to take that rear brake off, down to the rotor, take it off and back off the star wheel, placing the new rotor back on and off checking till it spins free. reinstall it all, and your done.
    odd but most times you need to open the parking brakes so they even touch the new rotor when you work the e brake.
  3. #3 Re: Need some help with new rear rotors/calipers
    oh, heres a little tip. just unbolt the caliper bracket, and lift it off, no need to take the caliper off it for this task.
  4. #4 Re: Need some help with new rear rotors/calipers
    Toledo, Ohio
    Thanks Scottydoggs for the super fast reply!!
    I think this is the first time I've ever done rear rotors on the GP.
    Passenger side seemed to slide right on. Hopefully I didn't damage anything tapping the rotor to get it snug.
    I'm doing the fronts Wednesday or Thursday too. Doing Impala powerstop calipers/rotors and pads...as well as the AcDelco ready struts. Should be easier not having to reach deep into the trunk!
    Sent from my SM-N910V using Tapatalk
  5. #5 Re: Need some help with new rear rotors/calipers
    im 6'6 so it was not all that bad of a reach for me lol but i could see it being rough for most.
    only damage going on is the wearing of the e brake shoes as it drags. some will just drive it till it rolls free, not the best plan but it works.
    and your gonna need an alignment after the struts are installed.
  6. #6 Re: Need some help with new rear rotors/calipers
    Toledo, Ohio
    Lol, I'm only 5'8'' so that last nut was a stretch without actually getting in the trunk.
    I did my front axles last year and paid a little extra for a lifetime alignment at Goodyear....so I'm all set for an alignment after the 4 ready strut install.
  7. #7 Re: Need some help with new rear rotors/calipers
    Oct 2011
    Toledo, OH
    If the Powerstop calipers are painted or powdercoated, you are going to have to grind out the part where the pads sit or they are going to stick.
    7"
  8. #8 Re: Need some help with new rear rotors/calipers
    Toledo, Ohio
    I hadn't heard that about the powder coated powerstops. The pads seem fit right in the rear calipers. I'll test fit the fronts prior to installing.
  9. #9 Re: Need some help with new rear rotors/calipers
    Oct 2011
    Toledo, OH
    Quote Originally Posted by firstdue View Post
    I hadn't heard that before, but after 10k miles the outer pad on all 4 wheels on mine was worn at an angle to the wear bars from getting stuck on one side. This was their caliper/rotor/pad kit so all were new and matching. A few seconds with a file and the new pads float a LOT smoother.
  10. #10 Re: Need some help with new rear rotors/calipers
    ive had to grind many a pad ends so they slide well. happens all to often. best always to clean and then grease the hardware on the bracket, then put the pads in the bracket and slide them in and out to make sure they more freely. if they dont, grind the end of the pad edges where they rub.
    always re grease the slider pins too. clean the holes if they are caked with old dry grease.
  11. #11 Re: Need some help with new rear rotors/calipers
    Toledo, Ohio
    Thanks for the heads up!! Got the rear parking brake adjusted and the back rotates freely with no noise!!
    Got the front ready struts in, so much easier than the rear. Being able to turn the wheel really helps.
    New Centric rotors (impala), pads and power stop dual piston calipers going on tomorrow!!
  12. #12 Re: Need some help with new rear rotors/calipers
    Toledo, Ohio
    New calipers were super easy to install and now i have tons of brake! It might be my imagination but it seems to nose dive more than before.
  13. #13 Re: Need some help with new rear rotors/calipers
    Toledo, Ohio
    Before and after
  1. GXP Rotors with C5 calipers?
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2012, 01:11 AM
  2. Looking to get new rotors and painted calipers, how much?
    By tcman49 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2011, 02:20 PM
  3. Want new calipers, rotors, and pads, but...
    By LALAW in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2009, 08:24 PM
