Thread: abs, trac light, abs self test noise
Results 1 to 10 of 10
  1. #1 abs, trac light, abs self test noise
    Sep 2011
    Mtl
    Hi all,
    2007 GP base
    I checked the other posts
    http://www.grandprixforums.net/threads/105274-Traction-control-turns-on-when-entering-and-leaving-parking-spaces
    http://www.grandprixforums.net/threads/105834-Trac-Brake-ABS-lights-on-C0050-and-C0095
    The abs self test pump activates once after a short distance of driving. Aftera longer drive, it engaged a few times then the abs service light and tractionlight came on. Shut off the car turn it back, went away then came back. Readonline sometimes it glitches.
    Its coming on regularly now, and sometimes before the lights come on, doing aregular stop the brake pedal pulsates, like the abs activating at low speedthen the lights come on. Both the abs and traction control don't work.
    tried a regular obd ii scanner can't scan the codes, has to be abs scanner,checked brake fluid level its okay.
    Read online that sometimes its the contacts of the speed sensors, or wiresfrayed going to the wheel hubs sensor integrated into the hub .
    Sometimes its the wheel hub.
    It could also one day taking the wheels off and examining the wiresclosely even disconnecting the connectors and applying grease if we have any.
    Could look at the abs control module connector.
    Last year we changed the tie rod ends and the driver side front wheelhub.
    other thing, when we put the summer tires on, one of the sensors wasn't readingprobably due to low battery as its the originals on there.
    The tire pressure sensor light turned on, just like in winter time so that'sokay. But now I notice that is not coming on, only the abs and service light, now the tire pressure light is on too.
    it seems to be very hard to come by a scanner that can scan the abs codes. Unless anyone has any ideas please.
    thank you
  2. #2 Re: abs, trac light, abs self test noise
    Nov 2012
    Madison
    The scanner I bought a month ago. It told me where to look.
    https://www.amazon.com/Innova-3100i-...00WSS5A4I?th=1
    other than that start by checking the wiring
  3. #3 Re: abs, trac light, abs self test noise
    GTP Level Member
    Oct 2014
    Watch the wheel speed sensors (4 of them) while driving. My guess is one will drop out momentarily causing your abs to fire up. That's where to look for bad wire or hub.
  4. #4 Re: abs, trac light, abs self test noise
    Nov 2013
    pittsfield ma. 01201
    Had same problem awhile ago with car running I started to wiggle wire harness until abs traction control came on. It was my wire harness front right ordered a new one from parts geek replaced about 2 feet of harness good luck
  5. #5 Re: abs, trac light, abs self test noise
    Nov 2012
    Madison
    Quote Originally Posted by markpa View Post
    What do you mean? watch them where?
  6. #6 Re: abs, trac light, abs self test noise
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    you can watch each wheel speed signal with a scan tool but if the system is setting a code, get the code read and go from there.
    these old vehicles use passive wheel speed sensors, they are ok at speed but the signal strength weakens the slower the wheel turns, this may cause signal fallout...the ebcm sees this as wheel slip and activates the abs system...resulting is a false abs event...typically, this happens at parking lot speeds.
    read the code to isolate the problem sensor.
    unplug the sensor and ohm check the sensor (not the harness to the ebcm) it should ohm approx 800 -1300 ohms iirc (find the spec). its its out of spec, replace the hub assembly
    set your ohm meter to a/c volts...spin the tire by hand...its should generate an a/c voltage or 0.1 volts or higher...the faster its spins, the higher the voltage. If both those are ok
    -disconnect the ebcm connector and ohm check the wires from the ebcm to the wheel speed sensor harness.
    2004 comp g
  7. #7 Re: abs, trac light, abs self test noise
    Nov 2013
    Hey Bud get an abs scan it will give you a better idea whats going on and save your self a lot of money before you start changing wheel bearings advance or pep boys might have an abs code reader you can use
  8. #8 Re: abs, trac light, abs self test noise
    Sep 2011
    Mtl
    Sorry for the delay, thank you Daviddawg, Spazzz, and Markpa. Very useful information to check with the voltmeter, and the scanner. I did inquire locally for a scan, but the places I contacted wanted to charge. We managed to remove the wheel and saw that one of the wires was frayed on the wheel bearing connector. The shop charged labour for it, just about under warranty and charged for a bracket. It maybe came on once since then maybe as a fluke, but so far seems okay.
    https://drive.google.com/open?id=1Bx...k_qFQqGgQjoA_s
    Thanks
  9. #9 Re: abs, trac light, abs self test noise
    Jan 2018
    Canada
    So just an update, I had a local garage, tell me bearing needed changing in the front, and I would still have the light come on and their scanner showed it was the bearing again. They changed it again, and costed some money. The light would still come on at random when turning.
    abs_wires.jpg - Google Drive
    I managed to check the wiring and the one of the wires were frayed going to the bearing. I had help to solder it in. I ended up buying the Dorman 970-047 harness.
    Thank you all for your help.
  10. #10 Re: abs, trac light, abs self test noise
    Nov 2013
    Glad you got is fixed its funny just started having same problem again my splice must have failed
  1. ABS light and Trac Off light come on at same time
    By kking89 in forum Brakes/Suspension/Chassis
    Last Post: 10-26-2013, 04:16 PM
  2. Brief grinding noise, felt in brake pedal/abs/trac light
    By KZOO3800 in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2013, 02:08 AM
  3. ABS light on, Trac Off light on, New hubs all around
    By tdm571 in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2011, 07:44 PM
  4. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  5. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
