Thread: ABS light not coming on cluster
Results 1 to 5 of 5
  1. #1 ABS light not coming on cluster
    Mar 2019
    Richmond Hill, GA
    Hi, with key on, I have no light on cluster. Is there a way to replace bulb on these clusters? Any recommendations on how to address this issue?
  2. #2 Re: ABS light not coming on cluster
    Yes, there are bulbs. Pop the cluster out and see if it's burnt.
    97-03 there is a bulb I believe, not sure if 04-08 has then in the board itself.
  3. #3 Re: ABS light not coming on cluster
    Mar 2019
    Richmond Hill, GA
    Ok, I’ll check it out. It is an 05
  4. #4 Re: ABS light not coming on cluster
    Oct 2014
    portland oregon
    Sent from my SM-N920V using Tapatalk
  5. #5 Re: ABS light not coming on cluster
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    It's an led soldered to the board. I don't remember the number offhand.
  1. Regal GS cluster idiot light problem.
    By Scottydoggs in forum General Tech Discussion
    Last Post: 05-15-2012, 10:22 AM
  2. Oil light coming off and on
    By BlackNRedGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-24-2011, 03:31 PM
  3. PLEASE HELP! Low Coolant Light Keeps Coming On
    By goodol84 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-02-2010, 06:22 PM
  4. Cluster light change
    By J06GT in forum Audio, Security & Visual Electronics
    Last Post: 01-21-2010, 10:33 AM
  5. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
