Thread: Trac, Brake, ABS lights on, C0050 and C0095
Results 1 to 19 of 19
  1. #1 Trac, Brake, ABS lights on, C0050 and C0095
    SE Level Member Metal Links's Avatar
    Dec 2013
    NJ
    I just replaced my right rear hub with a Detroit axle brand hub and all my lights are still on. What else could it be? Same codes are still on even after replacing the hub.
    I should add. It started happening a few months ago only when I had a passenger and I put it in gear. Now it happens as soon as I start the car. Couldn't really fix it over winter.
  2. #2 Re: Trac, Brake, ABS lights on, C0050 and C0095
    St. Louis
    Check all the wiring to it and make sure it's good. Other than that could be a bad EBCM.
  3. #3 Re: Trac, Brake, ABS lights on, C0050 and C0095
    Dec 2013
    NJ
    Could I repair the ebcm myself? The wiring seems like a pain to trace, could it be a bad ground somewhere (where is the ebcm/speed sensor ground)?
  4. #4 Re: Trac, Brake, ABS lights on, C0050 and C0095
    Nov 2013
    pittsfield ma. 01201
    Had the same problem last month front left wheel wire harness bad only had to replace about 2 feet of harness and plug got a new harness from parts geek about 35 bucks .
  5. #5 Re: Trac, Brake, ABS lights on, C0050 and C0095
    Dec 2013
    NJ
    I doubt it's the front left, already replace the hub and wire(there was water in the strink tube around the wires).
    C0050 - Right Rear Wheel Speed Circuit Malfunction
    C0095- Right Rear ABS Solenoid No. 2 Circuit Malfunction
  6. #6 Re: Trac, Brake, ABS lights on, C0050 and C0095
    Jul 2010
    Coquitlam,BC,Canada
    Check wiring and connections; the connectors can be problematic.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Trac, Brake, ABS lights on, C0050 and C0095
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    If it changes with adding a passenger, it's clear the wiring harness and/or sensor are moving with the suspension travel. It's probably binding or shorting somewhere by the wheel.
    I'd do like everyone suggested and look there.
    And using a Detroit Axle part; Their steering racks are notorious for almost immediate failure. It's possible you picked up a dud, but those are super easy to test. Just spin the wheel with a multimeter handy.
  8. #8 Re: Trac, Brake, ABS lights on, C0050 and C0095
    Nov 2013
    Hey Metal I just said it was my front left as an example found it by playing with the wires and it set off the abs light.The wiring is noted for going bad near the plug that connects to the wheel bearing not the wheel bearing wire its self good luck man.
  9. #9 Re: Trac, Brake, ABS lights on, C0050 and C0095
    Dec 2013
    NJ
    Thanks, I'll check when it's not raining. How would I check the connector? I picked up an extra pigtail at the junkyard so I could test the hubs easier, that I could splice in. Do I just perform a continuity test that the connector is good?
  10. #10 Re: Trac, Brake, ABS lights on, C0050 and C0095
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Use a pick to pull out the tabs on the connectors a little bit.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  11. #11 Re: Trac, Brake, ABS lights on, C0050 and C0095
    Dec 2013
    NJ
    Does anyone have part numbers for the female connectors or will I have to grab some from the junkyard and hope they're not broken?
  12. #12 Re: Trac, Brake, ABS lights on, C0050 and C0095
    GTP Level Member
    Jun 2016
    Cleveland ohio
  13. #13 Re: Trac, Brake, ABS lights on, C0050 and C0095
    GTP Level Member
    Jun 2016
    Cleveland ohio
    You will probably just have to buy another wheel bearing for the female connector on the bearing itself
  14. #14 Re: Trac, Brake, ABS lights on, C0050 and C0095
    Dec 2013
    NJ
    Thank you RickisRad but I need the rear connectors, which seem harder to locate. Also the male is on the hub and female is on the wire(I guess the male prongs go into the female is how that's determine? Kinda confusing). The only markings are "PED 7", light gray connector, red seal with two locking tabs.
    If I can't find a part number I'll pull the nicest set I can find from the Upullit tomorrow, and see what they want for a EBCM.
  15. #15 Re: Trac, Brake, ABS lights on, C0050 and C0095
    Nov 2012
    Madison
  16. #16 Re: Trac, Brake, ABS lights on, C0050 and C0095
    GTP Level Member
    Jun 2016
    Cleveland ohio
    sorry I missed the "rear" part!! LOL :/
    Never fear spazzz is here!!!
  17. #17 Re: Trac, Brake, ABS lights on, C0050 and C0095
    Dec 2013
    NJ
    Spazzz, do you think it could just be the wiring or could it be the new hub or EBCM?
  18. #18 Re: Trac, Brake, ABS lights on, C0050 and C0095
    Jul 2010
    Coquitlam,BC,Canada
    For the fronts, the plug on the vehicle side is problematic. Could be the same for the rears?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  19. #19 Re: Trac, Brake, ABS lights on, C0050 and C0095
    Nov 2012
    Madison
    Quote Originally Posted by Metal Links View Post
    well the obvious choice is to jack it up ...high.... peel back the wire loom to inspect the wiring. You already know what the fronts looked like, so why would the rears be any different.
    Start with that. The hub shouldnt be it when right out of the chute nothing changed.
    Me....I would have used the best hub out there. Even though everyone is a somewhat gamble for longevity. But I would say the SFK,Timken and Delcos might fair better than a 50 dollar special.
    Then I would replace the Harness anyway because 2004 GP in WI winters. Thennnnnn if I still had to deal, I would send the ABS module in.
    That's about the best I can do.
    Read this.
    https://ls1tech.com/forums/ls4-perfo...ntrol-fix.html
  1. ABS and Trac Off lights
    By Speedy1973 in forum General Tech Discussion
    Last Post: 02-11-2014, 08:33 AM
  2. ABS/Trac E-Brake Light SOLUTION
    By robinsone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2014, 05:46 PM
  3. Trac OFF + Parking Brake Light on while accelerating
    By EJOUIE in forum General Tech Discussion
    Last Post: 03-06-2012, 12:05 AM
  4. ABS/Trac Off Lights on
    By trailshredder in forum Brakes/Suspension/Chassis
    Last Post: 10-31-2010, 05:59 PM
  5. ABS and trac off lights
    By probuilder1 in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2009, 06:31 AM
