Thread: Trac OFF + Parking Brake Light on while accelerating
Results 1 to 6 of 6
  1. #1 Trac OFF + Parking Brake Light on while accelerating
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    this problem is intermittent, but seems to happen most often when I accelerate with at least 75% throttle. The trac off light and the red parking brake light both come on while I am accelerating and will remain on most of the time until i brake. Car acts normally while they are on and my wheels are not spinning or anything.
    Note that it is not the low trac light, but the trac off light. It is the same light combo that comes on when you engage your parking brake. I make sure to completely release the parking brake before driving.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  2. #2 Re: Trac OFF + Parking Brake Light on while accelerating
    SE Level Member 03limitedgtp's Avatar
    Sep 2011
    ohio!
    Take it to a gm dealer it maybe your wheel bearings or speed sensors
  3. #3 Re: Trac OFF + Parking Brake Light on while accelerating
    A parking brake light can be a badly adjusted sensor, low brake fluid in the master cylinder or a few other things.
  4. #4 Re: Trac OFF + Parking Brake Light on while accelerating
    Charles City, IA
    Yeah start by checking the fluid level, and be sure the float is floating in the master cylinder.
    SMGPFC Two Nipple General
  5. #5 Re: Trac OFF + Parking Brake Light on while accelerating
    Newnan, GA
    New info: the problem seem to be related to the slope of the car rather than the amount of throttle. For example 75% throttle on flat ground would cause it to happen, but just enough throttle to move the car on a steep hill also sets it off. Braking and sloping the car the other way makes both lights go away.
    Also it isn't just the parking brake light coming on. The "Trac Off" light is also coming on and off simultaneously with the brake light.
  6. #6 Re: Trac OFF + Parking Brake Light on while accelerating
    SE Level Member PALMCASTER GT1's Avatar
    PALMDALE CA
    dude that just happened to me this morning with my donut tire on and the pressure was low on it , after checking the pressure on all my tire's..... wala , no more light's . check your tire pressure ALWAY'S...
    04 GT1
  1. Parking brake warning light on after fluid change
    By aziff in forum General Tech Discussion
    Last Post: 05-02-2011, 10:06 AM
  2. parking brake light on dash
    By Jcal1120 in forum Brakes/Suspension/Chassis
    Last Post: 09-19-2009, 08:16 PM
  3. rumbling car and parking brake light
    By CMURDAx in forum General Tech Discussion
    Last Post: 09-05-2009, 08:30 PM
  4. Inspection/Parking Brake light on
    By c002529 in forum Brakes/Suspension/Chassis
    Last Post: 01-25-2009, 10:41 PM
  5. parking brake light???
    By kingd44 in forum General Tech Discussion
    Last Post: 02-20-2008, 11:38 PM
