Thread: Popping noise when turning? What might it be?
Results 1 to 13 of 13
  1. #1 Popping noise when turning? What might it be?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys I recently just developed a pretty loud popping noise whenever I turn the wheel 75-100% lock in either direction. Not sure if maybe it's an axel. Maybe it's the rack and pinion that's also leaking ps fluid or maybe it's the lca? Thoughts?
    Sent from my LG-H901 using Tapatalk
  2. #2 Re: Popping noise when turning? What might it be?
    Nov 2012
    Madison
    My popping was the springs binding(SSCs).
    I made spring isolators out of 1/2 ID clear vinyl hose.
    Just did it this weekend. No more binding not a creak,pop or scrunch. Usually happened on cold or wet days.
  3. #3 Re: Popping noise when turning? What might it be?
    HUDSON
    Make sure the rack and pinion mounting bolts are tight.
  4. #4 Re: Popping noise when turning? What might it be?
    SE Level Member Keko's Avatar
    Nov 2016
    California
    Popping/cracking noises can come from bad CVs when turning
    [Daily] 2002 GTP 40th Ann - FSIC, dp+plog, 3.3", ported LIM, HAI, front+rear sway bars, poly mounts, zzp tune for now :/
    [Fun] 2012 mazdaspeed3 - dp, 3" intake, FMIC, HPFP, Custom tune, lots of other goodies
  5. #5 Re: Popping noise when turning? What might it be?
    Oct 2015
    Quote Originally Posted by Keko View Post
    I called up my dad and asked him. He said it wasnt the cvs making noise because the popping noise will happen even when I'm not moving. Does that sound right?
  6. #6 Re: Popping noise when turning? What might it be?
    Nov 2016
    California
    Quote Originally Posted by suitercrew View Post
    Maybe if you are stationary and you move turn the wheels from side to side. If the CV is really bad I guess it might pop, but usually the popping noises get louder the faster and sharper you are cornering so doing it while stationary would be the least stress possible.
    Do you see any grease coming off either CV? Mine flinged grease all the way up on the coolant overflow reservoir.
  7. #7 Re: Popping noise when turning? What might it be?
    Oct 2015
    My passenger side seems to have a little grease around the boot but not anything crazy. My driver side is dry.
  8. #8 Re: Popping noise when turning? What might it be?
    May 2014
    Cincinnati, OH
    I've had bad sway-bar endlinks cause a popping noise when turning, especially when not moving or at slow speeds.
  9. #9 Re: Popping noise when turning? What might it be?
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    My popping years ago, different vehicle, was worn inner tie rod ends. Check for play at 3 & 9 0'clock.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  10. #10 Re: Popping noise when turning? What might it be?
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    Same thing happen to me. The vertical (front) control arm bushing was bad. It was original bushing and was never replaced. This issue among some other suspension issues led me to rebuilding mostly everything. For control arms and bushings, I replaced the entire control arm with Moog brand.
  11. #11 Re: Popping noise when turning? What might it be?
    Oct 2015
    Quote Originally Posted by NotEnoughGPs View Post
    I am in that process right now. I was actually wanting to ask what control arms to go with. I know the moog ones are supposed to be the best but they are also a pretty good chunk of change. So i guess my questions is there really that much of a difference between the moog and like acdelco? Do the moogs perform better or just have a better track record of longevity?
  12. #12 Re: Popping noise when turning? What might it be?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    I believe the difference is the bushings, noise/wear etc.
  13. #13 Re: Popping noise when turning? What might it be?
    Oct 2015
    Has anyone used the mevotech lca"s http://www.rockauto.com/en/moreinfo....id=401&jpid=29
  1. popping noise when turning right?
    By tichota126 in forum General W body
    Last Post: 03-24-2013, 04:28 PM
  2. 02 GTP Popping noise when turning at slow speeds. Intermediate shaft?
    By OcalaGTP in forum Brakes/Suspension/Chassis
    Last Post: 11-29-2012, 07:16 AM
  3. Popping Sounds When Turning?
    By ljmonnin12 in forum Introductions/Noob Questions
    Last Post: 05-06-2011, 09:05 AM
  4. another popping thread....while turning
    By cmashark in forum General Tech Discussion
    Last Post: 04-02-2009, 04:46 PM
  5. popping sound when turning...?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2008, 07:49 AM
