I'd like to take the calipers off the CompG and repaint them. The ABS needing a TechII on mine has me worried about letting it just leak out. A couple suggestions so far are to use plastic wrap under the reservoir cap (dunno how much that will do), and vacuum caps might plug the hole in the fitting.
Any ideas? Maybe a regular bolt the same size? (which is?)
Thanks.
