Thread: Changing brake bias?
Results 1 to 9 of 9
  1. #1 Re: Changing brake bias?
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Can you change the rotor/caliper so one side has more clamping force? Shouldn't you be braking before the turn and not in the turn? I understand it can help a little, but it seems you should be more focused on items that help you turn when not on the brakes.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  2. #2 Re: Changing brake bias?
    Oct 2015
    Toronto
    Quote Originally Posted by LeadfootCJ7 View Post
    My thought was that reducing the amount of surface area of the pads would reduce the friction on rotors and change the braking bias. Something cheap and easy.
    This is is a small scale adjustment that I hope will help with trail braking. Adjusting the steering should make a noticeable difference through the turns.
  3. #3 Re: Changing brake bias?
    Oct 2015
    Toronto
    Controlling roll for $4. Drilled and trimmed hockey pucks to fit between front right spring. Local car shop could order spacers in for $50CDN plus tax and shipping came to $80.
    Also installed cam bolts, they didn't look that substantial comes with a plastic bushing to add to offset. I will measure the camber tomorrow try it Saturday and re check next week. Hoping to get +/- 3 degrees on the front.
  1. Changing brake bias
    By gambler87 in forum Brakes/Suspension/Chassis
    Last Post: 03-26-2016, 11:08 AM
  2. Front/rear brake bias adjustment?
    By industrialfish in forum Brakes/Suspension/Chassis
    Last Post: 07-08-2014, 03:02 AM
  3. Question about Changing Brake Line
    By Calikid219 in forum Brakes/Suspension/Chassis
    Last Post: 09-05-2012, 09:05 PM
  4. How dirty should brake fluid be before changing it?
    By skeelo58 in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2011, 10:10 PM
  5. changing brake lines
    By mdotson29 in forum Brakes/Suspension/Chassis
    Last Post: 06-24-2011, 12:33 PM
