Thread: Front/rear brake bias adjustment?
Results 1 to 8 of 8
  1. #1 Front/rear brake bias adjustment?
    Oct 2011
    Toledo, OH
    In the process of moar low, so I also bought shiny rotors and pads since it'll all be apart anyway.
    Notice the rear brake pads look damn near new as far as thickness goes. They are 30k old minimum, probably older.
    Do the rear pads tend to last for ever, or am I not getting **** for use out of them for some reason?? Parking brake works though. Also I bled all 4 corners about 5k miles ago, stealership replaced one rear brake caliper soon after that (unrelated). At first I thought the caliper they replaced wasn't working, but the other side looks identical. At 96k and the rotors are probably original given how ****ing hard they were to take off.
    Any thoughts? Dealer invoice just says they replaced the caliper + fluid. But the parking brake was a LOT stiffer, so would they have replaced the pads too?
    7"
  2. #2 Re: Front/rear brake bias adjustment?
    Feb 2010
    TN
    70% of the braking is done with the Front brakes 30% rear so this is about normal
  3. #3 Re: Front/rear brake bias adjustment?
    GTP Level Member
    Aug 2012
    st louis park, MN
    I'm at about 100k and the rear pads and rotors are still meaty. I just replaced both rear calipers, not that that is relevant.
    Based on nothing other than what I've observed of wear, I'd say it is more like a 90 / 10 bias.
  4. #4 Re: Front/rear brake bias adjustment?
    all 4 corners wear at the same rate on my car, and i got f bodys up front.
    my last truck, a 03 gmc the backs wore out before the fronts every time. theres more back brake then you think these days in newer cars.
  5. #5 Re: Front/rear brake bias adjustment?
    Oct 2011
    Toledo, OH
    Isn't that because there is more pistons up front than in back? The same amount of volume through the lines moves the fronts less further than the rear.
    7"
  6. #6 Re: Front/rear brake bias adjustment?
    front and back brakes are separate. one has nothing to do with the other.
    my 03 gmc had 4 wheel disk, dual calipers front and back, used the same pads front and back too. calipers were identical. back brakes new from the factory wore out before the fronts, and we all know how good factory pads are, you'll never have a set last longer.
  7. #7 Re: Front/rear brake bias adjustment?
    hangover park IL
    there are two inline proportioning valves on the two rear circuit lines, both located near the rar of the car (near trailing arms)
    you can replace these with adjustables to increase the pressure. factory settings are low enough to make sure the rear tires will not lockup in the rain with no weight in the back....thats it...no more, so if you drive with subs in the trunk, you can add pressure. but you still do not want them to lockup under panic braking.
    it just sucks to get both valves adjusted the same.... never checked caliper pressures of caddy's and the like so id guess there's a chance the oem inline valves might be set higher on these models than the W cars...
    ~James~ Psychotic Gearhead
  8. #8 Re: Front/rear brake bias adjustment?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Turbocharged400sbc View Post
    That makes sense to me.
    7"
  1. Question about 06 GXP front and rear brake rotors and pads
    By path2011 in forum Brakes/Suspension/Chassis
    Last Post: 07-14-2013, 10:44 PM
  2. can front brake assembly be put on rear??
    By exofis in forum Brakes/Suspension/Chassis
    Last Post: 04-19-2011, 05:09 PM
  3. Front to rear brake line replacement - need advice
    By bxfl in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2010, 09:56 AM
  4. parking brake adjustment
    By CMURDAx in forum General Tech Discussion
    Last Post: 12-29-2009, 08:04 AM
  5. E-brake Replacement and adjustment
    By mustang gt in forum Introductions/Noob Questions
    Last Post: 08-02-2009, 11:42 AM
