Thread: Need help with Tire alignment & frame
Results 1 to 5 of 5
  1. #1 Need help with Tire alignment & frame
    Mar 2014
    New Orleans
    I went to firestone today to get an alignment because I hit a curb at 5-10 mph while it was raining I was slowing down to make the turn and my front wheels skid into the curb no damage just needed alignment untill my tire on the passenger side came off the (rim was already cracked) so I found a deal on 4 rims with tires for 125 put the new rim on replaced rear tire as it was 260/60/17 fire stone said the front passenger tire was all good except the caster ? I think he said the frame was bent and couldn't align that the frame needed to be straightened all I had was a little wobble during breaking the car has traveled on the highway over 1500 mile trips at a time I new it was wrecked when I brought it is it safe to drive the car still the wobble is 4 1-10 scale it's about the same as before but I would only feel it under hard breaking wich I thought was the roators maybe I never went over 40mph but it seems to get less noticeable I wanna keep the car I just don't want to literary ride till the wheels fall off
  2. #2 Re: Need help with Tire alignment & frame
    slot the strut bolt or get a camber bolt for it. unless its so far out of whack the frame or lca is bent real good.
  3. #3 Re: Need help with Tire alignment & frame
    Mar 2014
    New Orleans
    Camber bolt on caster ?? And wym by slot the strut
  4. #4 Re: Need help with Tire alignment & frame
    damn, i got em mixed up. could be a bent strut too.
  5. #5 Re: Need help with Tire alignment & frame
    Mar 2012
    NC
    Caster is usually caused by a bent lower control arm or a shifted subframe. Take a really good look at the affected lower suspension side and see what happens. Otherwise, caster isn't a wear angle...but it can cause a pull.
  1. Kinda irritated, is this tire defect or alignment?
    By FriboRage in forum Tires & Wheels
    Last Post: 09-29-2014, 07:56 PM
  2. Will a 04 Sub frame fit in my 97?
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 12-19-2012, 11:07 PM
  3. Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:05 PM
  4. sub frame
    By YoungGTP in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2008, 02:48 PM
