Thread: Clunking noise coming from the front.
Results 1 to 9 of 9
  1. #1 Clunking noise coming from the front.
    SE Level Member marlonrjs24's Avatar
    Feb 2016
    Every time I start driving or coming to a stop I hear this "CLUNK" coming from the front end. Does anybody know what can it be. Thanks.
    Sent from my SM-N920T using Tapatalk
  2. #2 Re: Clunking noise coming from the front.
    Could be motor mounts, CV axles etc.
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  3. #3 Re: Clunking noise coming from the front.
    Feb 2016
    I had everything replaced. I was thing it may be the lower ball joints.
  4. #4 Re: Clunking noise coming from the front.
    St. Louis
    If you haven't replaced the ball joints or control arms then I would start there. You can get the Dorman lower control arms that come with new ball joints pretty cheap, and that ensures you get new control arm bushings and ball joints all at the same time and you don't have to f with drilling out the rivets on the old arms to get the joints out. The bushings can also be a cause of your clunk. Since you didn't state what year or how many miles are on it I would assume they need to be done by now as well.
  5. #5 Re: Clunking noise coming from the front.
    Feb 2016
    It's a 01 GP se with 326,000 mi. I know it has a **** load of miles.
  6. #6 Re: Clunking noise coming from the front.
    St. Louis
    No worries, my 00 GPGT has 365K on it and I've probably replaced just about everything under it by now, lol... When the wheels fall off, I put 'em back on.
    With that amount of mileage on it if you haven't replaced the control arms/ball joints then that's what I'd go for next.
  7. #7 Re: Clunking noise coming from the front.
    Feb 2016
    Imma go ahead and do that. This noise is so annoying.
  8. #8 Re: Clunking noise coming from the front.
    Banned
    sub frame bushings. 99% sure
  9. #9 Re: Clunking noise coming from the front.
    Feb 2016
    I was thinking in replacing those sub frame bushing too
  1. Clunking noise from front end
    By PrixieGirl69 in forum Engine
    Last Post: 01-06-2014, 11:20 AM
  2. Trying to figure out the noise coming from front wheels 04 GTP
    By Bandit1228 in forum General Tech Discussion
    Last Post: 08-30-2012, 06:56 AM
  3. Clunking noise in front end 04 gtp!!!!
    By justin98 in forum General Tech Discussion
    Last Post: 11-08-2011, 03:19 PM
  4. *Clunking Noise From Front Left*
    By CleanGP in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2009, 01:12 PM
  5. odd noise coming from front wheels
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 04-15-2009, 09:32 PM
