Thread: hey guys got a stereo/alternator question
Results 1 to 14 of 14
  1. #1 hey guys got a stereo/alternator question
    Apr 2014
    Ontario
    Im going to be putting a sundown x12 1250watts rms. Its gonna be on 2 ohms at 1400w on my amp. Will i need a new alternator or just new batteries aaaaand are there even better alts available for 3.8?
  2. #2 Re: hey guys got a stereo/alternator question
    Aug 2012
    Calgary AB
    powerbastards alts.I have one 220+ w. I am running 2400w.Works for me.
  3. #3 Re: hey guys got a stereo/alternator question
    Apr 2014
    Ontario
    Will i even need a new alt or would 2 batteries do?
  4. #4 Re: hey guys got a stereo/alternator question
    Aug 2012
    Calgary AB
    Try with what you have now and see how it goes.But the ALT. would be the way to go.
  5. #5 Re: hey guys got a stereo/alternator question
    Aug 2012
    Calgary AB
    What is your total RMS?
  6. #6 Re: hey guys got a stereo/alternator question
    Apr 2014
    Ontario
    For the amp or the sub4400W RMS 2-Channel High Current Amplifier • 4400W RMS x 1 @ 1 Ohm Bridged • 2200W RMS x 2 @ 0.5 Ohm Stereo • 1400W RMS x 2 @ 1 Ohm Stereo • 1400W RMS x 2 @ 1 Ohm Stereo • 800W RMS x 2 @ 2 Ohms Stereo • 500W RMS x 2 @ 4 Ohms Stereo
    The sub is 1250 rms
  7. #7 Re: hey guys got a stereo/alternator question
    GXP Level Member
    Mar 2015
    Tomball
    4400w rms is a continuous draw of 314 amps at 14V, chances are that the normal current draw will be in the 50 amp range with short bursts of over 150 under normal 20 something listening habits. (Not taking into account losses from the amp)
    That at said if you do a lot of freeway driving then a second battery is the way to go. If you just drive here and there on short trips then batteries and alternator.
    i have run 1500 watts rms (class A and an A/B) with a 63 amp alternator and when I did at least a 40 mile drive a day everything was fine but on Friday and Saturday night I would ride with my friends down the strip and the normal kid route and set off car alarms at the movie theater and crap like that. I would come out on Sunday to a dead battery. Happened 3 weeks in a row so I added a second battery and a PAC 80 amp relay instead of an isolator and never had another problem.
    Jeff
  8. #8 Re: hey guys got a stereo/alternator question
    Antioch, IL
    whatever your amps fuses are you will never draw above that safely so go from there.
    2009 Challenger SRT8
    Expert at being gay.
  9. #9 Re: hey guys got a stereo/alternator question
    GXP Level Member
    Mar 2015
    Tomball
    Sure just go with that.
  10. #10 Re: hey guys got a stereo/alternator question
    Apr 2014
    Ontario
    It wont be running at 4400 full tilt I only have one sub right now that ill probably hook up at 1400w but it could probably handle 2200w at .5 ohm im just scared for my electrical
  11. #11 Re: hey guys got a stereo/alternator question
    GTP Level Member
    springfield IL
    An xtra battery for sure along with the big 3 in 1/0...
    go with welding cable also. it's great copper wire and priced nicely!!
    temco, royal excelene or eb flex brands
  12. #12 Re: hey guys got a stereo/alternator question
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    I did big three a semi battery and a 1.5 farad capacitor. I run the 2k watt amp and power inverter off the battery
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  13. #13 Re: hey guys got a stereo/alternator question
    GTP Level Member
    springfield IL
    The caps are a waste of money....let me say that again WASTE OF MONEY!!!
  14. #14 Re: hey guys got a stereo/alternator question
    Apr 2014
    Ontario
    Quote Originally Posted by tc300 View Post
    Yeah, ive done enough reading to figure out theyre a gimick. Better to get another battery and make sure you have strong electrical.
  1. '08 gxp ho alternator question
    By masonv6 in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2015, 03:08 PM
  2. Alternator question for 98 GTP
    By jcleary82 in forum General Tech Discussion
    Last Post: 01-12-2015, 01:48 AM
  3. alternator question?
    By lance4682 in forum General Tech Discussion
    Last Post: 12-11-2013, 09:11 AM
  4. alternator question
    By bluprix in forum Shops and Community Heroes
    Last Post: 07-16-2010, 01:59 PM
  5. Alternator question
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2010, 07:04 PM
