Any reason to run the power wire to the bat instead of just running it to the terminal on the fuse block?
because you wana pull everything straight from the battery. you dont wanna pull your power away from your fuse block because then that will short other appliances in your car
#2
Re: run the power cable from battery to trunk - FINISHED!! PICS!
That's correct
How To: E-Brake Pwn
2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
Looking For - 3" in DP with Cat. PM me if selling
#3
