Thread: run the power cable from battery to trunk - FINISHED!! PICS!
Results 1 to 20 of 54
  1. #1 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    Any reason to run the power wire to the bat instead of just running it to the terminal on the fuse block?
  2. #2 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    SE Level Member blackbonnie's Avatar
    Jan 2009
    grand rapids, MI
    Quote Originally Posted by WhiteGT View Post
    because you wana pull everything straight from the battery. you dont wanna pull your power away from your fuse block because then that will short other appliances in your car
  3. #3 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Quote Originally Posted by blackbonnie View Post
    That's correct
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  4. #4 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    May 2008
    Ontario
    Cool, thanks for the info, makes sense.
  1. Battery Compartment Mount
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 09-08-2008, 05:37 PM
  2. Convert a GP to battery power. Could it be done?
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 09-03-2008, 09:24 PM
  3. Finished Gen V Install Pics
    By Street Wolf in forum General Tech Discussion
    Last Post: 07-20-2008, 07:33 PM
  4. Interesting battery
    Last Post: 07-07-2008, 10:07 AM
  5. Small battery
    By Arkanzan Wheeler in forum General Tech Discussion
    Last Post: 05-24-2008, 10:33 PM
