Thread: HID/Ballast Problems
Results 1 to 7 of 7
  1. #1 HID/Ballast Problems
    Apr 2012
    North Dakota
    The light on my passenger side sometimes wont turn on if i turn my lights on and off a couple of times it will then turn on but there is about a 50% chance it turns on. Is this the ballast or the bulb. And also now it wont turn on at all. So should i just buy a new bulb and ballast or just a ballast? I know it is a 55w Ballast but how do i find the right replacement or will any 55w ballast work.
  2. #2 Re: HID/Ballast Problems
    Aug 2013
    McDonald PA
    Probably need a relay harness
  3. #3 Re: HID/Ballast Problems
    Apr 2012
    North Dakota
    is there any way to figure out if its ballast or harness?
  4. #4 Re: HID/Ballast Problems
    Jul 2010
    Coquitlam,BC,Canada
    Sounds like a bad ballast or a bad ground. Swap the bulbs and see if the problem follows or stays.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: HID/Ballast Problems
    Nov 2012
    Madison
    Quote Originally Posted by Bronco Boy View Post
    ^^ditto^^
    swap the ballast around and make sure you have bare metal grounds
    What brand ballast do you have? Any ol 55watter will do.
    I personally am paranoid about those things. For matched brightness and startup I replace in pairs
  6. #6 Re: HID/Ballast Problems
    Apr 2012
    North Dakota
    Quote Originally Posted by spazzz View Post
    ^^ditto^^
    the kit is a DDM Kit 55W 5000k. does that help anything ha and i will try to fix the ground but does this kid usually have a ballast go out or tend to get a bad relay harness?
  7. #7 Re: HID/Ballast Problems
    Antioch, IL
    DDM harness fuse by the battery like to blow/melt. but that would affect both lights not one.
    I dont have a problem with mine igniting, but the womens car has vvme and once in a great great while one light doesnt want to ignite.
    2009 Challenger SRT8
    Expert at being gay.
  1. Help with ballast
    By Timing in forum Audio, Security & Visual Electronics
    Last Post: 09-29-2012, 05:44 PM
  2. HID Ballast Went Out
    By 05CompG in forum Visual/Body Modifications
    Last Post: 03-14-2011, 03:43 PM
  3. PCM and HID Ballast
    By jshifti33 in forum General Tech Discussion
    Last Post: 07-23-2010, 10:41 AM
  4. HID Ballast
    By carl06GT in forum Visual/Body Modifications
    Last Post: 05-17-2009, 10:23 PM
