Thread: PCM and HID Ballast
Results 1 to 6 of 6
  1. #1 PCM and HID Ballast
    SE Level Member jshifti33's Avatar
    South Bend, IN
    The question I have is a two part question.
    Part I: I have HID headlights and as I understand the ballast's for them are essentially high voltage transformers creating a large magnetic field in the process. Am I correct in this thinking?
    Part II: If I am correct in part 1 would the ballast being to close to the PCM cause problems considering the magnetic field of the ballast?
    Thanks in for any insights you can give.
  2. #2 Re: PCM and HID Ballast
  3. #3 Re: PCM and HID Ballast
    Outer Space
    Quote Originally Posted by jshifti33 View Post
    Your over analyzing it. My ballast are literally 6 inches away from my PCM...no issues at all.
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: PCM and HID Ballast
    Bastard Reptile's Avatar
    Kansas City, MO
    But what about the warp bubble for faster than the speed of light travel?
  5. #5 Re: PCM and HID Ballast
    South Bend, IN
    Thanks for the insights. I just didn't want fry my PCM.
    P.S. Reptile, I have already solved the warp bubble problem. As it turns out all you have to do is flash your PCM with a picture of Chuck Norris.
  6. #6 Re: PCM and HID Ballast
    Kansas City, MO
    Is there anything that dude can't do? Quantum physics, devide by zero....he's teh awesomeness.
  1. Fuel pump ballast resistor question
    By millfire517 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-26-2010, 01:43 AM
  2. Bulb or ballast?
    By corsagtp in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2010, 04:09 PM
  3. Good Ballast locations.
    By RyanL in forum Visual/Body Modifications
    Last Post: 03-23-2010, 03:48 AM
  4. HID Ballast
    By carl06GT in forum Visual/Body Modifications
    Last Post: 05-17-2009, 10:23 PM
  5. ballast mounting
    By Toasty in forum Visual/Body Modifications
    Last Post: 03-31-2008, 12:40 AM
