Because your amp has 4 terminals this makes it easier kinda, basically you wire each sub in parallel down to 2 ohm like this and because your amp has two pairs of of terminals they are internally wired parallel so that 2 ohm turns to 1 which you want. So just then connect the one postive and negative from each speaker to each terminal after you wire the speaker itself in parallel as per the picture. Does that make sense?
Sent from the Milky Way
