I haven't been into car audio for a few years but i would call Pioneer probably mid tier on my list of brands. That amp looks good from the features, key on being its CEA compliant so it should put out its rated power. Get some nice 4 or bigger gauge power and ground wire (smaller the number the beefier). I recommend KnuKonceptz, I got an amp install kit from them included RCAs, remote wire (but it was tiny to I used some thicker wire I had laying around, 17ft power (4ga) 3ft ground, and like 50ft of speaker wire and inline fuse. Only thing it didn't have was a battery terminal bolt you need because you cant get another ring on the stock terminal (I tried). Might also want to concider the big 3 if you get light dimming issues. I'm running 500w rms with no issues tho. Ask away, I did the whole car audio research thing for weeks and then dove into my install, its pretty straight forward. I can clear up some questions if you have more.
4ga, KnuKonceptz Power Wire
Battery terminal post bolt thing, can be had at autozone for like 7 bucks.
Sent from the Milky Way
