Quote Originally Posted by abc View Post
My '08 didn't have a HUD so I just went with a new head unit. I lost the clock and date from the DIC but the new stereo has a clock. Everything else on the DIC is working. Although my front & back tire pressures are switched, but I don't know if they were that way before the new stereo.
New head units with USB are cheap these days. I got a DUAL head unit with 18 watts x 4 and replaced the rear 6x9's with Kicker 693's. Sounds almost as good as a home theater.
I think your tire pressures being switched is because at some point the tires got rotated without relearning the sensor positions... 08's dont have the passive system, they have an actual sensor in each wheel assigned to a particular position. When you move tires around, the sensor reporting for, say, Rear Left will still report for rear left, even if you moved it to front right.
But yeah, replacing the HU only loses steering wheel controls and DIC calendar functions. Everything else is retained as long as you get the proper interface, I use the Metra GMOS-04 with zero issues.
