Thread: Ipod Cable Solution for 2008 GXP
Results 1 to 11 of 11
  1. #1 Re: Ipod Cable Solution for 2008 GXP
    Aug 2013
    North Shore
    My '08 didn't have a HUD so I just went with a new head unit. I lost the clock and date from the DIC but the new stereo has a clock. Everything else on the DIC is working. Although my front & back tire pressures are switched, but I don't know if they were that way before the new stereo.
    New head units with USB are cheap these days. I got a DUAL head unit with 18 watts x 4 and replaced the rear 6x9's with Kicker 693's. Sounds almost as good as a home theater.
  2. #2 Re: Ipod Cable Solution for 2008 GXP
    Pennsylvania
    Quote Originally Posted by abc View Post
    I think your tire pressures being switched is because at some point the tires got rotated without relearning the sensor positions... 08's dont have the passive system, they have an actual sensor in each wheel assigned to a particular position. When you move tires around, the sensor reporting for, say, Rear Left will still report for rear left, even if you moved it to front right.
    But yeah, replacing the HU only loses steering wheel controls and DIC calendar functions. Everything else is retained as long as you get the proper interface, I use the Metra GMOS-04 with zero issues.
    Sport Edition Kv5 18x8
  1. Aux cable for Ipod hookup in 2006 grand prix
    By Jenrasa in forum Audio, Security & Visual Electronics
    Last Post: 07-23-2015, 10:26 AM
  2. 2008 shift cable issue
    By TigerFan66 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-11-2012, 01:02 PM
  3. HID Help? Anyone have a solution?
    By szalajka05 in forum Visual/Body Modifications
    Last Post: 12-04-2011, 03:05 PM
  4. A non welding solution
    By Mad Monkey in forum Off Topic Discussion
    Last Post: 09-23-2009, 02:22 PM
  5. IAT solution
    Last Post: 02-12-2009, 10:11 PM
