Thread: re-occurring problem w/dash connector, melting/killing battering
Results 1 to 5 of 5
  1. #1 re-occurring problem w/dash connector, melting/killing battering
    PA
    Hey Everyone,
    2002, Grand Prix, GT. 4 dr., auto tans.
    I am getting ready to replace this item for the second time in about two years. I have been smelling the order of burning candles, faint but there. The last time this happened the following occurred; I went to use the car one day and found the interior fan on and the radio playing, w/o the key in the ignition. It turned out to be the connector behind the radio and fan controls. It is a large one, looks like a flat computer cable. It had melted, causing the connection and allowing those accessories to be energized w/o the key. I am smelling that oder again and it is only a matter of time before this part goes again. Has anyone else had this problem and can it be stopped? is this a factory defect or recall situation? I'm also afraid it could start a fire!
    Is this something I can replace myself? I have never had the dash apart, but not afraid to try it with some guidance.
    Thanks in advance for any help!
    Regards,
    Scott
  2. #2 Re: re-occurring problem w/dash connector, melting/killing battering
    Enfield, CT
    did you check for shorts?
  3. #3 Re: re-occurring problem w/dash connector, melting/killing battering
    PA
    No, I have not done that yet. Just wanted to see if this was an issue others were having.
    Thanks for the reply.
  4. #4 Re: re-occurring problem w/dash connector, melting/killing battering
    Pennsylvania, USA
    I've honestly never heard of that, but like HighOctane said, it's most likely a short. When you have some spare time, take a quick peek at the wires coming out of the connector for any spots that look burnt, are kinked, or are missing insulation. It might just be a fluke and somehow a wire got pinched or damaged in some way.
    Good example, I kept blowing fuses for my interior lighting and no one I spoke to could help lead me to the problem. One day when I had the headliner down to tighten my OnStar antenna, I realized the wires that run to my driver's side sunshade/vanity mirror had somehow rubbed all the way through to layers of insulation and the wire insulation itself. Every once in a while they must have moved just right to touch and would short out, blowing the fuse. I solved it with electrical tape.
  5. #5 Re: re-occurring problem w/dash connector, melting/killing battering
    PA
    Thanks nik, it happens over a long period of time so I'll have to check carefully .
  1. Connector and Cooling fan problem
    By jphoppe1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2014, 09:41 PM
  2. Air Injection Relay connector replacement problem!
    By eleindc in forum General Grand Prix Discussion
    Last Post: 07-25-2013, 01:54 AM
  3. Dash electrical problem!
    By Dzimmijs in forum General Grand Prix Discussion
    Last Post: 09-08-2012, 06:26 PM
  4. tail and dash light problem
    By GTPSHAWTY in forum Visual/Body Modifications
    Last Post: 07-23-2012, 02:17 AM
  5. Have an electrical Dash problem!!
    By Padawan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2008, 09:42 PM
