Thread: Installing Aftermarket CD player with factory bose
Results 1 to 8 of 8
itsme Installing Aftermarket CD... 02-24-2014, 10:06 AM
giannim Re: Installing Aftermarket CD... 02-28-2014, 03:29 AM
itsme Re: Installing Aftermarket CD... 02-28-2014, 08:10 AM
bcchar Re: Installing Aftermarket CD... 04-19-2014, 05:47 PM
itsme Re: Installing Aftermarket CD... 04-19-2014, 09:41 PM
cavell Re: Installing Aftermarket CD... 05-01-2014, 08:20 AM
Rksqd1 Re: Installing Aftermarket CD... 08-11-2014, 01:41 AM
itsme Re: Installing Aftermarket CD... 08-11-2014, 07:55 AM
  1. #1 Installing Aftermarket CD player with factory bose
    Sep 2013
    Iowa
    i have searched a ton, and my buddy who professional installs cd players/remote starts etc gave me some info so figured i'd pass it on. if it is already posted here feel free to delete this.
    my fiance has a 2002 Grand Prix GTP Sedan, Factory Bose stereo without OnStar. i was super nervous about installing the cd player because all over the web it states you will have to use PAC kits, or line out converters, or rewire the whole car to bypass the factory amp.
    ive got a JCV cd player (forgot model number) and i wired it up, plugged it in an everything worked except sound. there if an additional clip for the factory stereo (you wont use) that has 4-5 wires on it, one of them being pink. i spliced the pink wire to the remote turn on wire on the cd player harness, and BOOYAH, it all works perfectly. turn signals still make noise, HUD still works (those were two other common reported issues when installing an aftermarket cd player). like i said, hope this helps someone out there.
  2. #2 Re: Installing Aftermarket CD player with factory bose
    Sep 2013
    Boise, ID
    Do you get any hissing noise coming out of the speakers? I had someone install this http://www.crutchfield.com/p_113KDCX...7.html?tp=5684 last weekend and it works great except there is a hissing noise coming from the speakers. I'm thinking maybe he didn't ground it properly. Anything else that could be causing it though? Can only hear it when the HU is on even if nothing is playing. Doesn't happen when it's off or in standby mode.
  3. #3 Re: Installing Aftermarket CD player with factory bose
    Sep 2013
    Iowa
    thats odd. i would check your grounds and make sure they didnt splice all four speaker wires together (ive seen it before) and just make sure all the connections are good. speakers sound great in my wifes car, no hissing or white noise or anything. sound great. let me know what you figure out
  4. #4 Re: Installing Aftermarket CD player with factory bose
    Dec 2013
    BC, Canada
    So you would use a t-tap connector and tap into the pink on the factory plug that isn't used and connect to the blue/white on the harness?
  5. #5 Re: Installing Aftermarket CD player with factory bose
    Sep 2013
    Iowa
    Quote Originally Posted by bcchar View Post
    Correct, I connected the pink wire on the factory harness to the remote\amp turn on. The bose amp works, HUD works, the steering wheel controls dont because I didnt buy the kit for it. It was super simple and works perfectly
  6. #6 Re: Installing Aftermarket CD player with factory bose
    Aug 2013
    mpls, mn
    my 99 has the 2nd black plug but i only had 1 pink wire coming from it. i cut off the plug and tossed it so 4 yrs later when i went back to stock, i had no idea where to plug the pink wire into the factory hu. the junkyard car i found had the black plug but also had 3 more wires in it. that i did not use since the 3 wires were in the main harness on my car. i just compared the color scheme and figured it out. my hu has hi/lo equilizer. not the 5 band style some hu have. maybe that is why wires on black plug are different? or maybe the wiring got tweaked from 99-00-01-02
  7. #7 Re: Installing Aftermarket CD player with factory bose
    SE Level Member Rksqd1's Avatar
    Jul 2014
    St louis mo
    I hooked the pink wire to the hot in run wire but I wouldn't have known what to do without this THANK YOU very very much. I even called crutchfeild and they sent me some kind of crossover which I was able to send back
  8. #8 Re: Installing Aftermarket CD player with factory bose
    Sep 2013
    Iowa
    Quote Originally Posted by Rksqd1 View Post
    glad i could help!
  1. Hooking up Aftermarket Deck in a '03 with Bose factory system/Amp
    By Kahn in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 10:49 AM
  2. Installing a aftermarket deck on a Bose system.
    By Pontiacman76 in forum Audio, Security & Visual Electronics
    Last Post: 09-07-2011, 09:19 AM
  3. installing an OEM cd player in a 06 gp gt
    By reallyfast1 in forum Audio, Security & Visual Electronics
    Last Post: 11-03-2008, 01:42 PM
  4. questions regarding adding an aftermaket cd player to bose/onstar
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 04:34 AM
