Thread: Need a 12v switched source for seat heaters.
Results 1 to 3 of 3
  1. #1 Need a 12v switched source for seat heaters.
    Dec 2011
    Southern Wisconsin
    Just installed a seat heater for a friend as a xmas present for his wife. I figured I would use the radio power since that comes on when the acc is on but I either tapped the wrong power wire or the radio power is constant. Where would you guys wire the power for the seat so that when the ignition is off, the seat heater is not powered?
    Thanks for any help guys.
    06 GP GXP "Charlize". TEP Street/Strip trans w/3.29 gearing. 20k trans cooler - standalone. DiabLew Tuned 91 oct. ZZP Catted downpipe, Magnaflow Cat-back.
    '13 Chevy Cruze 2LT M6.
  2. #2 Re: Need a 12v switched source for seat heaters.
    Nov 2011
    NY
    Put a relay in controlled off the ignition circuit and powered directly from the fuse block. Done!
  3. #3 Re: Need a 12v switched source for seat heaters.
    Dec 2011
    Southern Wisconsin
    I ended up using one of these: http://www.autozone.com/autozone/acc...ier=32416_0_0_
    Then used the sunroof fuse and it works like it should.
    Thanks for the reply!
  1. 05 Grand Prix GTP...car overheating/ not heat from heaters
    By Rileys05GTP in forum General Tech Discussion
    Last Post: 02-19-2012, 02:08 AM
  2. Seat heaters???
    By duane9586 in forum General Tech Discussion
    Last Post: 03-20-2010, 09:21 AM
  3. Switched Ignition Source
    By Blackhawk in forum Audio, Security & Visual Electronics
    Last Post: 11-15-2009, 05:51 PM
  4. 12volt switched source?
    By nyydmb12 in forum Audio, Security & Visual Electronics
    Last Post: 10-19-2009, 06:45 AM
