Thread: 05 Grand Prix GTP...car overheating/ not heat from heaters
Results 1 to 11 of 11
  1. #1 05 Grand Prix GTP...car overheating/ not heat from heaters
    SE Level Member Rileys05GTP's Avatar
    Sioux City Iowa
    Hey I got a 2005 Comp G GTP with 70,500 miles on it, just recently the car started to get just under overheating on the gauge and the heater wont blow hot. Thought it may be a thermostat so changed that and it didn't help the temp gauge then just started moving and would still get just under overheating with no hot heat. So I took the car to my mechanic and he found that the water pump was bad so changed that. Still did not fix the issue. So then took the engine apart assuming maybe a bad head gasket or bad head. Had the heads sent into a auto shot and the heads are in perfect condition and didn't even need cleaned up. Really puzzled with what this problem could be were putting the engine back together tomorrow with new head gaskets.
    If anyone has any ideas please let me know!! Thanks
  2. #2 Re: 05 Grand Prix GTP...car overheating/ not heat from heaters
    Pennsylvania
    Fans not turning on?
  3. #3 Re: 05 Grand Prix GTP...car overheating/ not heat from heaters
    Bleed the cooling system on air??
    Did you even try that?
  4. #4 Re: 05 Grand Prix GTP...car overheating/ not heat from heaters
    Sioux City Iowa
    fans do come on, i don't think we bleed it
  5. #5 Re: 05 Grand Prix GTP...car overheating/ not heat from heaters
    SE Level Member Just Yourshadow's Avatar
    Fox River Grove, IL
    It sounds like a partly or in this case mostly clogged coolant passage. I would flush the radiator and motor to see if you can break thru anything that might be blocking coolant flow.
    I start $hit like it's got3800
    02 Regal - Best E/T - Wouldn't you like to f#cking know
    76 Kawi KZ900
  6. #6 Re: 05 Grand Prix GTP...car overheating/ not heat from heaters
    Sioux City Iowa
    ill try flushing radiator when it gets put back together
  7. #7 Re: 05 Grand Prix GTP...car overheating/ not heat from heaters
    Nov 2011
    south carolina
    Sounds like there was air in the system.
  8. #8 Re: 05 Grand Prix GTP...car overheating/ not heat from heaters
    GT Level Member Toms04compg's Avatar
    Michigan
    Bleeding the system probably shoulf of been your 1st step waterfpump usually leaks or howls when bad.
  9. #9 Re: 05 Grand Prix GTP...car overheating/ not heat from heaters
    GT Level Member thegipper's Avatar
    grafton, wi
    You definitely should of tried bleeding your system before tearing down the engine. Always start with the simple things first. My guess is you had air in your cooling system or a blocked coolant passage. Start by trying to bleed the air out of the system. If that doesn't help, try doing a coolant flush. Let us know the results.
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  10. #10 Re: 05 Grand Prix GTP...car overheating/ not heat from heaters
    Kansas
    I already recommended a flush in your intro thread. Still don't know why you pulled the heads.
  11. #11 Re: 05 Grand Prix GTP...car overheating/ not heat from heaters
    Sioux City Iowa
    Well put the engine back together with new head gaskets and the car runs perfect now and blows heat like hell. Thanks for the ideas
  1. 2002 Pontiac Grand Prix. Overheating
    By britnyh08 in forum General Tech Discussion
    Last Post: 03-03-2011, 04:18 PM
  2. Overheating Grand Prix
    By mhartwig in forum General Tech Discussion
    Last Post: 11-02-2010, 11:14 AM
  3. Grand prix GT 1998 Overheating
    By GrandPrixGT98 in forum General Tech Discussion
    Last Post: 10-11-2010, 07:07 PM
  4. 2002 Pontiac Grand Prix GT overheating!!
    By OLDSCHOOL22 in forum General Tech Discussion
    Last Post: 10-12-2009, 06:39 AM
  5. 96 grand prix overheating issue
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-10-2009, 12:37 AM
