Thread: LED Back up lights hack?
Results 1 to 20 of 21
  1. #1 LED Back up lights hack?
    Apr 2012
    Wyoming, MI
    I was wondering if there was a way to install a button in my car that would activate the rear back up lights while driving? For example, if some guy decided to tail me like crazy if I'm already speeding a lot (and can't get over to the other lane), I could flash it at him, the same way some people flash their brights to cars in front of them to get them to move over. Any ideas of how I would be able to install this hack/mod?
  2. #2 Re: LED Back up lights hack?
    wire a switch to the lights. but this is not legal.
    back in the day if you were driving around with the back up lights on you were looking for a race too. so some old timer may want to race you lol
  3. #3 Re: LED Back up lights hack?
    Apr 2012
    Wyoming, MI
    Would I have to wire in a separate power wire? How simple would the process be?
  4. #4 Re: LED Back up lights hack?
    you would wire them up like a set of fog lights. just tap into the power side of the light sockets. leave the factor wires so they still work when backing up.
  5. #5 Re: LED Back up lights hack?
    Apr 2012
    Wyoming, MI
    But wouldn't adding a switch to the power side make it so they don't work when backing up unless the switch is activated? Sorry, I'm a newb at car electricity.
  6. #6 Re: LED Back up lights hack?
    they would work when you flip the switch, when the switch is off the back up lights should work fine.
    you may even want to wire a relay up as well.
    like so.
    you can buy a fog light install kit for about 20 bucks. its everything in this pic plus the wiring.
  7. #7 Re: LED Back up lights hack?
    Apr 2012
    Wyoming, MI
    Is there a relay for the existing backup lights that I could just add a switch to that area of the wiring?
  8. #8 Re: LED Back up lights hack?
    there is but your not using it.
    im sure if you or i were more electrically savy theres a way to use the factory wires from the shiftier or something. but im not that guy. lol
  9. #9 Re: LED Back up lights hack?
    SWPA
    Mick you are thinking about this too hard. Just tap into the factory back up light wiring and run it to a switch. Run a power to the switch and you're done. The Back up lights still work in reverse, and you can turn them on without being in reverse.
  10. #10 Re: LED Back up lights hack?
    Apr 2012
    Wyoming, MI
    Where should I run the power wire from?
  11. #11 Re: LED Back up lights hack?
    Dec 2012
    Where 4T65E's were born
    Any power from a key on device, or even always on, it doesn't matter. You could even run your own from the battery/power dist. box if you really couldn't find one.
    Sold.
  12. #12 Re: LED Back up lights hack?
    Quote Originally Posted by mick777wauchope View Post
    i suck at this stuff but, this is to easy. you maybe over your head a bit.
    power can come from the fuse box in the car, you use a add a fuse thing for a extra power lead.
  13. #13 Re: LED Back up lights hack?
    Buy one of those led licence plate things and have it say back the **** off unless you want my rear bumper in your grill. If the other driver rear ends you it is their fault for following to close. Note this is not the safest method, but the asshole would learn to not tailgait ya.
    But I understand where you are coming from, not a day goes buy that I'm passing a line of cars going down the interstate and already doing 70+ mph in a 65 when some douchbag feels the need to ride my ass.
  14. #14 Re: LED Back up lights hack?
    what's so hard about tapping the brakes a couple times?
    and if you're not doing 10+ over and people are tailgating you, you're in the wrong lane.
  15. #15 Re: LED Back up lights hack?
    Idk how things are in Michigan, but here if you are doing more than 5 over you will get pulled over. Not that anyone obeys the speed limit anyway, its really bad here on a 2 lane road that is posted as 35 you will have people seriously doing 20-25 in one lane and someone doing 50 in the other.
  16. #16 Re: LED Back up lights hack?
    Dec 2012
    I don't usually have issues here in MI on freeways. Most are posted at 70, and I do 73-75 in the right or middle lane and don't have any problems. If I do, I move all the way over to the right and let them go by.
    Now in the city there are always drivers going 5-10 over the speed limit, and you will get pulled over in certain areas only doing 5 over. A road near me is posted at 35 in one section, and goes down to 30. Right where it goes down to 30, people dont like to slow down, cops are always hiding using radar on the 2nd or 3rd street down. I'm always seeing people get pulled over. Unfortunately that's my route to school so I always do like 31 or 32 in the 30 zone and get tailgated constantly since it's a one lane each way road and no passing allowed. Then what do I do? lol. See it's city roads that are the issue for me.
    Well one time I was on van dyke highway (70mph) and it's a 2 lanes, and everyone was doing 80 in both lanes. So I did 80 that time. Also on I-94 there are areas that are 55 mph, and some are 70. People just do 70 the whole way through (in all lanes so I do too) but I haven't seen anyone pulled over from that. Usually the right lane is doing like 65 in the 55 zones so it's not too bad.
    Sold.
  17. #17 Re: LED Back up lights hack?
    SWPA
    People seem to forget that the left lane is the PASSING lane and not the "fast" lane. Once you pass you get the f#ck back over to the right lane.
  18. #18 Re: LED Back up lights hack?
    From what the op was saying it sounds like he was I the process of passing when the guy was tailgating him. People do that all the time here, you will be passing a line of slow cars and some asshole will ride your ass even if you are doing 10+ over.
    Sent from A Galaxy Far Far Away........
  19. #19 Re: LED Back up lights hack?
    SE Level Member rockquarryman's Avatar
    Nov 2013
    so co
    Quote Originally Posted by slick2500 View Post
    yea true but that's in any state really but I like being the asshole that is doing 55 in the fast lane just to piss them off even more hahahahaha
    by the way mick if you want a power supply that is only on when the car is on try using the power wire that comes off your radio
  20. #20 Re: LED Back up lights hack?
    GTP Level Member
    springfield IL
    I just put up a led bar on my rear deck..... Have yet to use it!! But it's BRIGHT!! Haha
  1. 97-03 Climate Control Hack
    By 04CompG in forum General Tech Discussion
    Last Post: 02-14-2015, 12:26 AM
  2. No dash back lights
    By gpse2000 in forum Audio, Security & Visual Electronics
    Last Post: 07-01-2013, 08:32 PM
  3. calling all GPF trolls and hack artists
    By Bio248 in forum Off Topic Discussion
    Last Post: 09-05-2012, 08:08 PM
  4. Back up lights for tinted tails?
    By TheOtherNick in forum Visual/Body Modifications
    Last Post: 12-20-2008, 09:36 PM
  5. PRNDL Back Lights Not Working
    By POLECAT2007 in forum General Tech Discussion
    Last Post: 10-16-2008, 09:00 PM
