Thread: pre drilled holes under plastic speaker holder
Results 1 to 7 of 7
  1. #1 pre drilled holes under plastic speaker holder
    Nov 2013
    Florida
    Hi everyone merry christmas,
    I am installing my daughters system in here 02 GP and put the new ones in the plastic risers and cliped back in, I notice holes pre drilled to further anchor the plastic riser, any one know what size the screw that can be put in to lock the Plastic riser down tighter
    Thanks
    Jeff
  2. #2 Re: pre drilled holes under plastic speaker holder
    Nov 2013
    Florida
    Hey what do you know, the screws that came with the speakers fit the hole and hold the plastic riser tight, do you all install you new speakers in the risers, or omit and mount to metal?
  3. #3 Re: pre drilled holes under plastic speaker holder
    Jan 2012
    Philadelphia
    Install the new speakers in the risers if they fit in there
  4. #4 Re: pre drilled holes under plastic speaker holder
    Nov 2013
    Florida
    They did and I have the risers screwed to the steel feels pretty solid. Any one know what that little power wire is that comes out of the third brake light, I have a small 2 wire cord with a plastic plug in comming out of the third break light comes on with the key
  5. #5 Re: pre drilled holes under plastic speaker holder
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    That is wiring for the Bose amp.
  6. #6 Re: pre drilled holes under plastic speaker holder
    Nov 2013
    Florida
    I wonder if I can use this for the 250 watt amp I want to use to power the 2 6x9s
  7. #7 Re: pre drilled holes under plastic speaker holder
    Sep 2012
    Casper Wyoming
    I wouldn't trust it as enough current to support a very big amp. You could use it to turn the amp on. For that amp even that small I would still suggest at the least 8ga power and ground wire.
  1. 2002 broken back speaker cover - Bose 4 speaker deck
    By fmp3 in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2013, 06:10 PM
  2. Loud clunking sounds like plastic hitting plastic
    By ADrugDealer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-12-2012, 07:50 AM
  3. 180 tstat drilled or not drilled?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2009, 04:04 PM
