Hi, this is my first post. I have a 2001 Grand Prix GT. The entire radio, lights and all, stopped working. I'm trying to diagnose the problem. I checked the single fuse located near the glove box for continuity and it's good. What should I do next?
Did you pull it and check that it's actually good or maybe a test light on both sides?
I pulled it out and checked for continuity with an analog multimeter and continuity was good. I didn't use a test light.
All good with that then. There are two fuses IIRC. One is labeled a little vague.
Thank You!!! I didn't know there were two fuses so when I found one I didn't think to look for another. They are labeled RADIO, RADIO AMP. It was the Radio Amp 20 fuse that was blown. I would give you a big fat kiss if I could.![]()
