Thread: GoGroove Flexsmart Fm Transmitter?
Results 1 to 4 of 4
  1. #1 GoGroove Flexsmart Fm Transmitter?
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    Comp G with 6 disc, Monsoon
    I've read good reviews on the Flexsmart X2, so so reviews on the newer Flexsmart X3....never used a FM Transmitter, so not sure what to compare it to....
    Anyone with any experience with this specific device, or other FM Transmitters....
  2. #2 Re: GoGroove Flexsmart Fm Transmitter?
    a tape deck thing works better, the fm modulators really do sucks balls in the end.
    you can tap the cd changer input with a aux port. sound will be much better.
  3. #3 Re: GoGroove Flexsmart Fm Transmitter?
    Sep 2012
    That was my first impression after searching for them....but this specific GoGroove Flexsmart X2 has good reviews, and added bluetooth capabilities....besides I plan on getting an aftermarket radio pretty soon, so if it works like advertised it'll hold me over until that happens, and afterwards the wife can use it....
  4. #4 Re: GoGroove Flexsmart Fm Transmitter?
    all i know is i used one for my XM years ago. that will never happen again. big waste of money, they are not as loud, nor do they sound as good as a hard wired set up. that dead radio station will tune in and block its signal sometimes. aka, a pita. i took my antenna off my last truck, then clipped the modulator wire to the threaded nub, that was the best reception i could get.
    like i said, the tape deck adapter works way better. the aux input works the best. if you can install it.
  1. How Do I Reprogram My Keyless entry Transmitter??
    By 1999GTP1999 in forum General Tech Discussion
    Last Post: 03-09-2010, 09:33 PM
