Thread: Tachometer Stopped Working
Results 1 to 4 of 4
  1. #1 Tachometer Stopped Working
    Aug 2012
    Iola, KS
    Hello this is my first post. I have a 97 GTP, and one day last fall the tach needle dropped to zero and has been there ever since. I have read several forum posts about the crankshaft position sensor being the problem, but in all those the engine was misfiring or having some intermittent problems, where my engine is running fine. It's just the tack stays on zero. Any suggestions are much appreciated.
  2. #2 Re: Tachometer Stopped Working
    St. Louis
    Could be a bad cluster. Not sure if there is a fuse specifically for the tach, but could be that as well.
    And Welcome to GPF.
  3. #3 Re: Tachometer Stopped Working
    Jan 2012
    Philadelphia
    I was gonna say it could be the cluster, but Im not sure
  4. #4 Re: Tachometer Stopped Working
    Aug 2012
    Iola, KS
    I appreciate the replies, I'm gonna need to take the bezel off to get to the radio anyway, so I guess I'll plan on lifting the cluster out and do it all at once.
    Thanks !
  1. Replies: 1
    Last Post: 01-20-2013, 06:15 PM
  2. Heater stopped working
    By ls1camino in forum General Tech Discussion
    Last Post: 11-08-2011, 02:36 PM
  3. speedometer stopped working..
    By JoeC9107 in forum General Tech Discussion
    Last Post: 03-19-2011, 06:00 PM
  4. air con stopped working
    By Tha Ghost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-20-2011, 04:14 PM
  5. Replies: 2
    Last Post: 03-19-2010, 08:58 PM
