Thread: pairing amp to speakers.
Results 1 to 20 of 27
  1. #1 pairing amp to speakers.
    Oct 2013
    Canada
    *Original post* 120 rms Energy 6"x9" rear speakers
    85 rms Energy 5.25" front speakers
    both 4ohm
    Looking at buying Pioneer class FD 4channel amp model (gm-d8604)
    rated 100 rms x 4 @ 4ohm
    paired with after-market Pioneer head unit 122 rms x 4
    (Will this be too much power for my speakers? Also can I use existing wires and just connect amp to head unit harness input and output?) - Fixed - won't be too much power, but need new speaker wire)
    Thank you all for input and help
    -Link for amp http://www.crutchfield.com/S-uI3Pkq2...-GM-D8604.html
    -Link for head unit http://www.pioneerelectronics.com/PU...rs/DEH-P6900UB
    -Link for front speakers http://www.futureshop.ca/en-CA/produ...58ba7b72a5en02
    -Rear speakers http://www.futureshop.ca/en-CA/produ...754d1e96daen02
    Pontiac Grand Prix SE 2003
    http://www.sonicelectronix.com/item_...-GT5-2500.html
    http://www.sonicelectronix.com/item_...-GM-D8604.html
    http://www.pioneerelectronics.com/PU...ries/GM-D7500M
  2. #2 Re: pairing amp to speakers.
    Without knowing what you own (carwise) it's tough to give you much advice.
    I wouldn't suggest hooking up a head unit to an amp via factory wiring, but then, I'm not a audio guy. I followed the advice of buddies and ... let's say 3 years later I'm still very happy.
  3. #3 Re: pairing amp to speakers.
    gardner,mass
    The power will be fine. Just adjust your headunit more to the back a few clicks.
    Dont use factory wiring. factory speaker wire is like 22-24 gauge. Pick up a roll of 14-16 gauge and spend an afternoon running fresh wire.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  4. #4 Re: pairing amp to speakers.
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    I'm installing that very amp now.
    You won't, of course, be able to use the factory power wire. That amp requires a 8 gauge cable for both power and ground.
    I'm running RCAs to the amp for its input, and I'll be using 14 gauge wire for the speakers.
  5. #5 Re: pairing amp to speakers.
    Oct 2013
    Canada
    Sorry I don't quite understand, "Just adjust your headunit more to the back a few clicks." Does this mean don't put the volume too high? However, thank you everyone for your input! I will definitely look at buying 14 gauge speaker wire.
  6. #6 Re: pairing amp to speakers.
    Oct 2013
    Canada
    Quote Originally Posted by douger View Post
    Okay I looked at my headunit
    link for head unit
    It looks like it has 3 RCA pre-outs (1 I hooked to sub already) I can use RCA cables for input of amp like you're doing. For the output of amp should I take 14 gauge wire to my old wire and pull it through dash then hook to amp? Also, where is a good spot to mount a 4channel amp for main speakers/ where are you putting yours?
    2003 grand prix SE
    One more thing. Where is the head unit's amp? Will I miss the power from it or will the signal be automatically paired together since the RCA inputs for my new amp are coming from my head unit?
  7. #7 Re: pairing amp to speakers.
    gardner,mass
    Quote Originally Posted by Car Splicer View Post
    No what i meen is the front speakers have a lower rms than the rear, therefor you want to adjust the fader on the headunit like 2-4 clicks towards the rear so those put out more than the fronts.
  8. #8 Re: pairing amp to speakers.
    If you'd like nice wiring check out Knuconceptz, here's there amp kit page
    http://www.knukonceptz.com/productMa...llation%20Kits
    I called up because what I wanted wasn't listed quite the way I wanted it. I added more of their speaker wire, one double rca cable (did front/rear preouts) and one for the subs. The amp wiring (4 gauge) Then 80 feet of speaker wire. I had very little speaker wire left after doing all four and the sub. All the wiring was awesome quality and in three years, I've never had a single bit of dimming etc. That's running everything off one amp.
    As for install... see if your amp needs a certain orientation, if possible invert it and mount it below the rear deck. Keeps it out of the way.
  9. #9 Re: pairing amp to speakers.
    Oct 2013
    Canada
    Quote Originally Posted by Ginseng View Post
    Ahhh okay, thank you! I understand now
  10. #10 Re: pairing amp to speakers.
    Oct 2013
    Canada
    Thank you for the link for speaker wire! I'm not quite sure where "below the rear deck" is. Essentially in trunk by rear speakers underneath? I didn't really mention too much, but I do have a sub with amplifier wired in trunk. Is there anywhere near front of car I could mount the new amplifier? I could use less power wire and need a lesser gauge wire I think. Mainly I need locations of good grounding points. However, the rear of car is still a valid point for amplifier because I would likely buy another wiring kit and therefore get 17' of power cable.
  11. #11 Re: pairing amp to speakers.
    Hold on for about 30 minutes. I'm logging into PB. Yes.. up under between the rear deck speakers. I don't compromise about having room and fold down rear seats. In my case, it had to be out of the way.
    This is looking into the trunk while crouched down.
    Backseat down and looking out from inside the car
    Some of that wiring
    I may have gone overboard.
  12. #12 Re: pairing amp to speakers.
    Oct 2013
    Canada
    Some of that wiring
    Thank you! This is very helpful. Unfortunately I may have blown my tweeters. I'm not sure.. So I'm looking into the problem before buying an amp :/ sorry to ask more, but do you know how to test if your tweeters are not working properly? It seems to me like they aren't emitting very much sound. My woofers still sound great and are putting out good vocals at least. I do have a crossover in door as well. I think I put my head unit a little past 3/4 max to like 5/6 max when testing my sub out for a good full test drive and may have had slight clipping of my stock amp :'( do you know how to go about getting replacement tweeters? Also, would my rear 6x9 tweeters be blown as well if my front speaker tweeters are blown? It is very hard to tell in the rear as getting to the speakers requires taking out the entire back seat...
    -Link for speakers
  13. #13 Re: pairing amp to speakers.
    Sorry.. I don't, but someone will .
  14. #14 Re: pairing amp to speakers.
    GTP Level Member
    springfield IL
    Op, better (a lot better) coulda been had for money you spent on those speakers.....
    And on the amp also.....
  15. #15 Re: pairing amp to speakers.
    Oct 2013
    Canada
    Quote Originally Posted by tc300 View Post
    Haha, care to share what would be better? I spent $60.00 on those speakers because I bought them on sale.
  16. #16 Re: pairing amp to speakers.
    Aug 2012
    Fort Wayne
    link for head unit
    2003 grand prix SE
    I am running new speaker wires from the amplifier to the speakers. That involves pulling the sill plates and other trim so I can get access to the harnesses that run along the rocker panels. I ran the power cable down the right side, I'll run the speakers down the left side (you don't want them running together unless you like chasing down noises) and I'll run the RCAs under the console.
    My car has the Monsoon audio system and I'll mount the Pioneer amp in the same location, which is underneath the rear deck in between the speakers.
    The audio signals run from the head unit to the amplifier via the RCA cables. An added bonus with this amp is that it will turn itself on and off based on whether it's seeing an audio signal. There's no need to run a separate wire.
  17. #17 Re: pairing amp to speakers.
    Oct 2013
    Canada
    Okay, I think I can wire my amp the same way you are. Sounds like a good way to go and yes I will definitely put speaker wire down left and power down right haha. No power cable noise!!
  18. #18 Re: pairing amp to speakers.
    Banned
    Oct 2013
    Moorhead, MN
    You'll ruin speakers with too little power before you will with too much.
  19. #19 Re: pairing amp to speakers.
    Banned
    Oct 2013
    Moorhead, MN
    Very clean install Bill.
    Wanna hang out some time? =)
  20. #20 Re: pairing amp to speakers.
    Quote Originally Posted by Thompsju View Post
    Thanks and you don't know the half of it. Most of it's not even in the pics. My power wire actually is run in the factory loom on the right side of the car because I took out the 30 Monsoon wires. I put the LED turn signals and puddle lights/door light wiring into the factory connector where they were on previous years etc.
    On the hanging out, I'll pass. You have too many spare brackets still.
  1. pioneer ts G1642R speakers into front doors speakers?
    By thomasd2010 in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2013, 10:16 AM
  2. 6x9 speakers
    By Points70 in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2012, 10:48 PM
  3. new speakers
    By keenan00gtp in forum Audio, Security & Visual Electronics
    Last Post: 12-24-2008, 04:52 PM
