Thread: pairing amp to speakers.
Results 1 to 20 of 27
Threaded View
  1. #8 Re: pairing amp to speakers.
    Oct 2013
    Canada
    Quote Originally Posted by douger View Post
    I'm installing that very amp now.
    You won't, of course, be able to use the factory power wire. That amp requires a 8 gauge cable for both power and ground.
    I'm running RCAs to the amp for its input, and I'll be using 14 gauge wire for the speakers.
    Okay I looked at my headunit
    link for head unit
    http://www.pioneerelectronics.com/PU...rs/DEH-P6900UB
    It looks like it has 3 RCA pre-outs (1 I hooked to sub already) I can use RCA cables for input of amp like you're doing. For the output of amp should I take 14 gauge wire to my old wire and pull it through dash then hook to amp? Also, where is a good spot to mount a 4channel amp for main speakers/ where are you putting yours?
    2003 grand prix SE
    One more thing. Where is the head unit's amp? Will I miss the power from it or will the signal be automatically paired together since the RCA inputs for my new amp are coming from my head unit?
  1. pioneer ts G1642R speakers into front doors speakers?
    By thomasd2010 in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2013, 10:16 AM
  2. 6x9 speakers
    By Points70 in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2012, 10:48 PM
  3. new speakers
    By keenan00gtp in forum Audio, Security & Visual Electronics
    Last Post: 12-24-2008, 04:52 PM
