Thread: GXP key fob problem
Results 1 to 10 of 10
  1. #1 GXP key fob problem
    SE Level Member Rnungaray08's Avatar
    Apr 2013
    Milwaukee,WI
    Just got my GXP on friday. My key fob is acting up. The panic and trunk realease work perfect. But the lock and unlock act up a lot. I have to press down really hard and hold for a few seconds and itll work. But sometimes I have to press and hold a few times until it reacts. So i know the battery its not the problem. Could a new shell solve my problem? I found some on ebay that come with the shell and the buttons.
    2006 Grand Prix GXP
    Sport Red Metallic, 20% Tint
    Future Mods: Trans Cooler(Ordered)
    CAI, Intune with diablew tune, exhaust
  2. #2 Re: GXP key fob problem
    I live here. DirtDog's Avatar
    Jun 2012
    Have u opened urs up? Cause mine was doing that and turned out that the piece that holds the battery in place had come loose...I taper the insides into place and no more problem
  3. #3 Re: GXP key fob problem
    Apr 2013
    Milwaukee,WI
    Quote Originally Posted by marines542 View Post
    Ill recheck it tommorow morning. But its weird that the trunk release and the panic button work perfect
    2006 Grand Prix GXP
  4. #4 Re: GXP key fob problem
    Wichita
    I had that same problem when I got my GXP. Remote start didn't work either. I made the dealership replace the key fob. =]
  5. #5 Re: GXP key fob problem
    Jun 2012
    Lucky u lol I wish they'd mine now
  6. #6 Re: GXP key fob problem
    SE Level Member 05ls4gxp's Avatar
    Feb 2013
    macomb, mi
    open it up, and the reason those dont work is cause the rubber piece that touches the actual motherboard looking thing in the rob are worn out... i took a q-tip and put alcohol rub on it.. cleaned the side with the buttons and then put little tiny pieces of foil so the connection would be better.. and bam, have had no problems in 3 months
  7. #7 Re: GXP key fob problem
    Apr 2013
    Milwaukee,WI
    Quote Originally Posted by 05ls4gxp View Post
    Thanks it worked like a charm. At first it was too sensitive. But I cut little squares the size of the little black dot and glued it on. Now its perfect.
    2006 Grand Prix GXP
  8. #8 Re: GXP key fob problem
    Yoga city
    someone get rid this huge ass sig lol
  9. #9 Re: GXP key fob problem
    May 2013
    Michigan
    I had the exact same problem, my buddy told me about these things off eBay so I tried it. They work perfectly now.
    GM Key Remote Repair Pad Instant Button Fix Keylessfix | eBay
  10. #10 Re: GXP key fob problem
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    I too was looking for the answer to this about a month ago... found a pretty good solution that I will be making a how-to on sometime soon. I glued tin foil to mine at first and it worked for a while then I dropped the key and the glue broke loose... dunno if im just bad at glueing or what but I found some tin foil tape that works like a charm! its just like duct tape only its tin foil
  1. Need a direction to my GP's problem - FWD problem
    By isaac33 in forum General Grand Prix Discussion
    Last Post: 02-26-2013, 11:36 AM
  2. PCM problem??
    By fremmy182 in forum General Grand Prix Discussion
    Last Post: 01-15-2013, 07:26 PM
  3. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  4. HID problem
    By bziggy58 in forum Audio, Security & Visual Electronics
    Last Post: 10-15-2012, 09:28 PM
  5. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
