Thread: HID problem
Results 1 to 3 of 3
  1. #1 HID problem
    SE Level Member bziggy58's Avatar
    Apr 2011
    Minnesota
    I recently installed hids with relay harness in my 08 grand prix. Sometimes my low beams will only fire one bulb. I always turn light on manually so its not a drl problem. Any ideas?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    its the hdm solid state module. Looks like a small relay in your under hood fuse block. Drl is like 70% power. Headlights are 100%. The lower voltage reeks havoc on ballasts.. and relay harnesses.
    I know on the trailblazer they use a capacitor on the signal to run it at 100% all the time.
    I haven't personally done this on my 04 never had any issues....but I just found out recently this only effect 06+
    Sent using my Galaxy SIII on Tapatalk
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: HID problem
    Apr 2011
    Minnesota
    But even when I start the car and put the headlights on manually and never even let the drls come on it does it
  1. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. Key problem
    By kjohnson in forum General Tech Discussion
    Last Post: 04-24-2011, 12:32 PM
  4. new guy with a problem
    By sbellmore2010 in forum Introductions/Noob Questions
    Last Post: 11-01-2010, 05:42 PM
  5. Egr problem
    By silvermistgt2002 in forum General Tech Discussion
    Last Post: 04-16-2010, 09:33 PM
