Thread: Power Wire for Amp
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 Power Wire for Amp
    Sep 2012
    Cedar Rapids, Iowa
    This question has probably been asked many times but a search of the forum and quick look online turned nothing so I figured it couldn't hurt to ask it here one more time. So I have mounted my amp, ran the RCA and control wire to the head unit and ran a ground wire to a metal portion of the car. Then I took the power wire and ran it all the way to the front of the car under the trim and put all the trim back together. Here's the problem, now the power wire is sitting at the feet of the front passenger seat and I need to run it to under the hood to connect to the battery terminal. I can't seem to figure out the best way to do this, I can feel an area behind there that might be an easy place to drill into and run the wire through there but I don't exactly know what's behind it so I'm not so sure this is the best route to take. For those of you with GP's where did you run your power wire to your battery? I have a 2002 GP GT if that makes any difference. Thanks in advance.
  2. #2 Re: Power Wire for Amp
    Dec 2010
    DMV
    There's a grommet in the passenger footwell that you can run it through
  3. #3 Re: Power Wire for Amp
    Agreed.. nice big rubber (squarish) plug.
  4. #4 Re: Power Wire for Amp
    Yoga city
    either that for 2awg n smaller, if its bigger jsut drill
  5. #5 Re: Power Wire for Amp
    Sep 2012
    Cedar Rapids, Iowa
    Where does this gromet lead out under the hood? Also it feels very tight in there i dont know if my 6ga wire will be able to run through there
  6. #6 Re: Power Wire for Amp
    i took my pass side wind shield cowl off, and on the left side under the windshield i drilled a hole, and fed the amp power wire through the hole, it came out at the pass side floor, i tucked it behind the rug and ran it along the side to the trunk. you can take some vac line, cut it then put it over the amp line to protect it from the hole you drilled.
    only part that sucks is you ran it already, you cant feed it up, you have to feed it from the engine bay. so to do it this way you need to take the amp wire back out, and start over. this way you can have a in line fuse under the hood too close to the battery.
    my amp just needed a 12 v remote wire, i added a add a fuse to the wiper fuse, ran the remote wire from there, it only works if the key is to run.
  7. #7 Re: Power Wire for Amp
    I was able to put a 4 gauge through it. You need to make a hole for the wire. It leads out right next to the power steering rack on the passenger side. I think i have pics.
    Follow the red wire
    Once you get it started... look up fron under the car by the rack..you'll see it.
  8. #8 Re: Power Wire for Amp
    Saw what Scott mentioned. I was able to fed mine from the inside of the car out. My wire was new and had nothing on it.
  9. #9 Re: Power Wire for Amp
    Second note..
    If you are ever looking for a tool to route wires etc, Take a gear selector cable out of something like a GP. Cut one end off. Works awesome because it's strong and flexible.
  10. #10 Re: Power Wire for Amp
    the install kit i used had a inline fuse on the power line, so it had to fed from the bay, you also cant see the hole to feed it to where i drilled.
    truth is i didnt like that rubber block at all, seemed like the wire was to close to hot engine parts, and drilling that rubber block scared me. as the plug on the other side turns a odd way.
    the amp line just follows the washer fluid line to the cowl and it disappears.
  11. #11 Re: Power Wire for Amp
    Nice Scott.
    I brought mine up with the wire loom in that grommet. Actually it's in the loom and then comes out at the relay center and follows the body another 6inches to a foot over to the battery. The inline I added is probably 6 inches off the battery. It all tucks nice and clean to keep from having any of the issues you mentioned as your concerns in that area.
    Since I had most of the car gutted, I pulled all the monsoon wiring from front to back out of the loom, that amp wire went right into that same loom running down the length of the car and into the trunk.
    Becaus...I'm BillBoost
  12. #12 Re: Power Wire for Amp
    Yoga city
    uhm 6ga? really? i have a 00 awg wire running through mine lol if you can get the 6ga though it just quit lol jk. You should be able to just fine, and it will be under the brake booster, easier to push it from inside the car in to the engine bay.
  13. #13 Re: Power Wire for Amp
    lol you would be......the other problem i found was getting to the rubber block from under the car, seemed to be a tight area to work in. so i opted for my way.
    i think i spent more time debating with my self about going through the rubber block then i took drilling and dropping the wire from up top. it was very easy to do. i was hoping there would be only one panel to get through, (got lucky) fed it in, and it hit the floor. my brothers like "I SEE IT!" The rest is history.
  14. #14 Re: Power Wire for Amp
    Yoga city
    what kind of car he driving? that can make a difference where he runs
  15. #15 Re: Power Wire for Amp
    I ran passenger side. Jayke ran driver side. Scott... sounds like passenger side.
  16. #16 Re: Power Wire for Amp
    Ps...I'm a normal sized human being. No issues working in there. Twas a bit tight, no issues though.
  17. #17 Re: Power Wire for Amp
    i like being me. its good to see over the crowds.
  18. #18 Re: Power Wire for Amp
    Yoga city
    i dont care i got the biggest wire here lol
  19. #19 Re: Power Wire for Amp
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    I tried getting my wire through that grommet for over an hour. Finally I lost my temper (which rarely happens), grabbed the drill, and made my own hole through the firewall. Ended up narrowly missing a wire loom. What is the secret to getting it through? I even tried a small copper wire and it only went in a little less than an inch and then it stopped up. Is it possible that some cars (2000) dont allow for this?
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  20. #20 Re: Power Wire for Amp
    I used a large pick to make a hole, then fed in the shifter cable I use for routing stuff and taped the power wire to it. Pulled it through. On others I've drilled a hole in the grommet.
  1. Running a power wire
    By Leroyy in forum 04+ Specifics
    Last Post: 08-14-2012, 04:15 PM
  2. Runnin power wire in an 04+ GP
    By painthorsemoe in forum Audio, Security & Visual Electronics
    Last Post: 05-08-2012, 07:51 PM
  3. Amp power wire help!!!!!
    By Goldoni in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2010, 08:00 AM
  4. new power wire
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 12-23-2009, 03:35 AM
  5. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
