Thread: Power Wire for Amp
Results 21 to 40 of 49
  1. #21 Re: Power Wire for Amp
    Sep 2012
    Cedar Rapids, Iowa
    So if I just wanted to drill through the firewall where would be the best place to drill to avoid missing wires, etc.
  2. #22 Re: Power Wire for Amp
    the area i drilled, under the windshield was wire free, but i still only let the tip of the drill bit go through. its also a dry area, no water gets under there.
  3. #23 Re: Power Wire for Amp
    Sep 2012
    Cedar Rapids, Iowa
    Where exactly under the windshield?
  4. #24 Re: Power Wire for Amp
    Yoga city
    still wondering what car this is
  5. #25 Re: Power Wire for Amp
    Jayke..I assumed W body...lol
  6. #26 Re: Power Wire for Amp
    Yoga city
    i dont know i cant assume anything here, once i do im wrong, tell this guy to drill somewhere that isnt safe, does he even realize what a gromment is or should we let him find out down the road.
  7. #27 Re: Power Wire for Amp
    I'm with you Jayke, unfortunately you must be using the invisible font today. He hasn't answered you yet.
  8. #28 Re: Power Wire for Amp
    Yoga city
    i know right? And its 6ga, come on now. you can get that through anything. my speaker wire is almost 6 ga
  9. #29 Re: Power Wire for Amp
    My speakers are Knu wire, which is in the round shell. I hear ya ... I hear ya.
  10. #30 Re: Power Wire for Amp
    Yoga city
    lol dammit respond to The Great One!
  11. #31 Re: Power Wire for Amp
    He did respond to me. LOL
  12. #32 Re: Power Wire for Amp
    pics from this thread http://www.grandprixforums.net/water...-fix-6961.html
    i drilled on the left side theres a divider, left and right side. so side closest to the fender, but next to the divider.
  13. #33 Re: Power Wire for Amp
    Sep 2012
    Cedar Rapids, Iowa
    Quote Originally Posted by jteske88 View Post
    Its a 2002 GP GT it says in the first post.
  14. #34 Re: Power Wire for Amp
    Yoga city
    lol i asked and it took this long to respon, dude just run that little itty bitty baby wire through the groment on the drivers side.
  15. #35 Re: Power Wire for Amp
    Sep 2012
    Cedar Rapids, Iowa
    Also I was unable to get the wire through either groment. I'd honestly be surprised if I could get my signal wire through the one. I think my best bet is to just drill through the firewall.
  16. #36 Re: Power Wire for Amp
    Yoga city
    no no no, get a phillips screw driveer and poke it through, like man if i can get the 00 awg wire in thats more than 5 sizes bigger than yours. come on now.
  17. #37 Re: Power Wire for Amp
    Sep 2012
    Cedar Rapids, Iowa
    It said it in the first post and I didn't see your post asking until just now. I'll try the one on the driver's side
  18. #38 Re: Power Wire for Amp
    Sep 2012
    Cedar Rapids, Iowa
    I'll check again but I'm pretty sure. All the wires leading there form a big bunch that completely fill some sort of tubing they are being fed through
  19. #39 Re: Power Wire for Amp
    Matt...
    Before you drill. pull back the carpet at the passengerside floor. Find the big square grommet thing I'm talking about. Now take a flathead and pry at the lines that you see in it. It's techincally just pushed in there. Once you have the 3/4" this piece out of the way, put your wire through the thin boot that's on the outside (a slice with a razor knife should work) then position the wire reasonably and push that piece you pulled out ....back into place and cut if needed.
    I've drilled through that piece, I've cut it ..I've pulled it out and stuffed it back in ... all work. I was trying to keep you with the best method.
  20. #40 Re: Power Wire for Amp
    Yoga city
    ive done countless gp power wires and have run them all the same way without issue. dont see how you or your car is special or maybe you are special........ed.
  1. Running a power wire
    By Leroyy in forum 04+ Specifics
    Last Post: 08-14-2012, 04:15 PM
  2. Runnin power wire in an 04+ GP
    By painthorsemoe in forum Audio, Security & Visual Electronics
    Last Post: 05-08-2012, 07:51 PM
  3. Amp power wire help!!!!!
    By Goldoni in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2010, 08:00 AM
  4. new power wire
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 12-23-2009, 03:35 AM
  5. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
