Thread: 01 GTP with bose and OnStar replace stereo without expensive wiring harness
Results 1 to 4 of 4
Draco 01 GTP with bose and OnStar... 03-31-2011, 11:10 PM
matt5112 Re: 01 GTP with bose and... 04-01-2011, 08:19 PM
Draco Re: 01 GTP with bose and... 04-06-2011, 09:27 AM
smitz327 Re: 01 GTP with bose and... 03-10-2013, 12:05 PM
  1. #1 01 GTP with bose and OnStar replace stereo without expensive wiring harness
    SE Level Member Draco's Avatar
    Bountiful Ut
    I have an 01 Grand Prix with Bose and OnStar. Is there a Way to wire my after market stereo without having to buy the 100$ wiring harness. I'm fine with rewiring a few things
  2. #2 Re: 01 GTP with bose and OnStar replace stereo without expensive wiring harness
    Stereo implies you're replacing everything.
    Do you mean just the head unit?
    If so, you just connect the pink wire to the remote wire from your new head unit and you'll be back in business.
  3. #3 Re: 01 GTP with bose and OnStar replace stereo without expensive wiring harness
    Bountiful Ut
    Thank you! Spending all this time trying to find out that one little peace of information. That Damn pink wire is all i needed to know.
  4. #4 Re: 01 GTP with bose and OnStar replace stereo without expensive wiring harness
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    This a copy from ramairgtp2! There are two plugs on the back of your stock radio harness. The smaller of the two with 4 wires? IIRC ( its been a while since I talked about this ) anyways there is a solid pink wire in the smaller plug. That is your cars amplifier power turn on wire. You wire up your HU with the wire harness adapter like normal and then you have your blue remote turn on wire from your HU... Connect that blue wire from your HU to the pink wire coming out of your dash for the Amp turn on. This will power your Bose amp like normal and give you sound.
  1. Special wiring harness for aftermarket stereo for newer gp
    By MattTheBaker123 in forum Audio, Security & Visual Electronics
    Last Post: 07-10-2012, 12:28 AM
  2. wiring harness aftermarket stereo
    By LeThAlREMiX in forum Audio, Security & Visual Electronics
    Last Post: 02-09-2011, 12:41 AM
  3. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
  4. adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    By s1795so2 in forum How To Write-Ups/Tech Tips
    Last Post: 04-19-2010, 07:10 PM
  5. questions regarding adding an aftermaket cd player to bose/onstar
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 04:34 AM
