This a copy from ramairgtp2! There are two plugs on the back of your stock radio harness. The smaller of the two with 4 wires? IIRC ( its been a while since I talked about this ) anyways there is a solid pink wire in the smaller plug. That is your cars amplifier power turn on wire. You wire up your HU with the wire harness adapter like normal and then you have your blue remote turn on wire from your HU... Connect that blue wire from your HU to the pink wire coming out of your dash for the Amp turn on. This will power your Bose amp like normal and give you sound.
