Thread: Special wiring harness for aftermarket stereo for newer gp
Results 1 to 8 of 8
  1. #1 Special wiring harness for aftermarket stereo for newer gp
    SE Level Member MattTheBaker123's Avatar
    Stillwater, Minnesota
    So i got a new stereo for my 2004 grand prix for christmas and it turns out i bought the wrong wiring harness for it and i cant find one anywhere. My friend tells me the newer gm cars need a special harness. Does anyone know where i can get one online for grand prixs 04 and up?
    Thanks.
  2. #2 Re: Special wiring harness for aftermarket stereo for newer gp
    Feb 2009
    Virginia
    Axxess GMOS-01 - Car data bus interface
    There's cheaper ones that utilize an internal speaker vs. integrating w/your factory speakers but I can never find it online. I grabbed one from a local audio shop for ~$25
    11 is louder than 10!
  3. #3 Re: Special wiring harness for aftermarket stereo for newer gp
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    its a bia....I bought one it was $120 bucks...and still didnt work right...had to tweak with it, man...the chime one and non-chime are uselss...they couldn't have made this part any harder.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  4. #4 Re: Special wiring harness for aftermarket stereo for newer gp
    Quote Originally Posted by I800C0LLECT View Post
    So when it says its supported for a non amplified gm vehicle what does that mean?
  5. #5 Re: Special wiring harness for aftermarket stereo for newer gp
    Feb 2009
    Virginia
    That means it is designed to be inline between the head unit and the speakers. Monsoon setups employ an amplifier. Therefore, instead of being placed inline w/wires, it uses RCA's.
    The link I provided pointed towards a GMOS-01 w/o RCA's.
  6. #6 Re: Special wiring harness for aftermarket stereo for newer gp
    Ohio
    Quote Originally Posted by MattTheBaker123 View Post
    Thanks.
    I read all kinds of bad reviews about these harnesses, so I picked up a GMOS-04 at Best Buy for $99 cuz I wanted to be able to exchange it if it was defective. Turned out it was just fine - lots of wires to fuss with, but no cutting/splicing of my factory wires needed. I also got the PAC SWI-JACK (~$40 at Amazon) to keep the steering wheel controls working.
    @I800COLLECT got it right - if you have a Monsoon system and want to keep using the amp, then get the GMOS-04. If your new radio doesn't have two sets of pre-outs, you'll need line converters as well since it does use RCAs. If you don't have a factory amp, then get the GMOS-01 - but if you use this harness with a factory amp, I'm pretty sure you'll be sending an already-amplified signal to the amp - not a good thing. The GMOS does require some tweaking, but once you get it right you'll still have the chimes that ding when your fuel is low - I'd run out of gas if I didn't have that.
  7. #7 Re: Special wiring harness for aftermarket stereo for newer gp
    thanks for the feedback i purchased the GMOS-01 hopefully everything will be working soon enough
  8. #8 Re: Special wiring harness for aftermarket stereo for newer gp
    GT Level Member TJeno's Avatar
    Jun 2012
    Ames, Iowa
    I've gotta ask, did it work?
  1. Aftermarket Stereo Problems?
    By RedFace in forum Audio, Security & Visual Electronics
    Last Post: 02-23-2011, 01:23 AM
  2. Wiring harness
    By Dedlydragoness in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2009, 04:51 PM
  3. Aftermarket stereo in 06 GP with Monsoon
    By GXP Bill in forum Audio, Security & Visual Electronics
    Last Post: 10-14-2009, 01:23 PM
  4. Static in Aftermarket Stereo
    By KobAil in forum Audio, Security & Visual Electronics
    Last Post: 01-25-2009, 12:19 PM
  5. zzp wiring harness
    By TheOtherNick in forum Audio, Security & Visual Electronics
    Last Post: 11-03-2008, 02:47 PM
