ok so i installed my hid last week both lows and fogs, the lows have a relay harness wired up and the fogs harness is getting wired up this weekend, but my problem is that when i turn them on, the high beam light comes on and is dim. I've read the thread about swapping around the wires but i only have a single beam kit and only 2 wires in the plug, so i got a wiring diagram and the wires are correct the black wires are going to ground and the red wire for the harness is going to the tan wire for the lows in the factory wiring. and the fogs are wired up correct also the black wire for the hid blub is going to the black wire in the socket and the blue wire for the hid blub is going to the purple wire in the socket, so since i have them all wired correctly why is the light still on? But another weird thing is that the light only comes on when the fogs are on. So today while i was checking the wires, i took some readings and this is what i got,,
-With all the lights on i got a reading of 4.89v on the Lt green wire which is the wire for the highs
-with just the lows on(fogs off) i got a reading of 66.5mv on the Lt green wire
-and when i hit the high beam switch all the lights turned off, like there suppost to and i got a reading of 14.52v, so all thats good
so the only thing thats not right is that im getting 5v on the high beam side when all the lights are on..why?
the only thing i can think of is that i dont have the relay harness hooked up, because when i put the lows in the light was dim but since i have the relay harness working the light doesn't come on with just the lows on
so will wiring up the relay harness for the fogs fix my problem?..or is it something else?
btw the kits i have are
a 55w 8k 9007 kit from vvme
and a 35w 10k 880 kit from vvme
thanks for reading
