i have the bi xenon dual beam HID's if you get a kit with only low beams your high beam light on your dash will stay on. also when i turn my fog lights on my high beam indicator lights up just a little bit. it has to do with one of the prong connector in the HID harness. When installing my kit i didn't have high beams or fog lights because the high beam wire was crossed with the ground wire so i swapped those and everything worked properly. If you only have low a low beam kit your high beam indicator will always be on. Thats all i know
