Thread: Alternative for remote wire?
Results 1 to 14 of 14
  1. #1 Alternative for remote wire?
    Feb 2013
    Los Angeles
    Ok so heres my problem: I just almost finished installing a new sub and amp into the trunk of my grand prix, but I don't know where to connect the remote turn on for the amp. I have a factory hu and this is the wiring diagram for it: 1997-1998 Pontiac Grand Prix with 8 Speakers Wiring Information , the only problem is there is no pink remote wire in my car. So my question is: What do I connect the remote turn on wire to?
  2. #2 Re: Alternative for remote wire?
    Dec 2010
    DMV
    Anything that comes on with the car.
  3. #3 Re: Alternative for remote wire?
    Sep 2011
    Copperas Cove, TEXAS
    Yup, what Bluemajic said. Just don't attach it to the amp power wire or you will get speaker hop which is annoying and the amp will stay on constantly.
  4. #4 Re: Alternative for remote wire?
    If your radio has the spot for the connector, but the wiring doesn't have the connector, you should be able to go grab one and add it.
  5. #5 Re: Alternative for remote wire?
    Feb 2013
    Los Angeles
    so would the #3 wire, the power antenna work for this? Or should I use the #2 accessory 12 volt? or will I have to use the ignition wire?
  6. #6 Re: Alternative for remote wire?
    Yoga city
    the power ant, wire will be on when the radio is on, i put a power atenna in my masted 97, i usally in this case go to the fuse box and look for a 12+ switched source.
  7. #7 Re: Alternative for remote wire?
    Be careful using the power antenna. You might want to check that wire. Some head units bring the antenna down when you move off radio.
  8. #8 Re: Alternative for remote wire?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    use the # 2 12 volt accesory. ive even seome people use the lead of the back of the 12 volt outlet on the passenger side
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  9. #9 Re: Alternative for remote wire?
    or...just use what I suggested originally.
    Just saying.. I like my suggestions.
  10. #10 Re: Alternative for remote wire?
    Quote Originally Posted by jakeanator View Post
    i hooked my remote wire up to the fuse box, used a add a fuse, hooked it up to a fuse that is off when the car is off. works fine for my amp.
  11. #11 Re: Alternative for remote wire?
    Dec 2012
    Hawai'i
    I did the same thing. Mines wired to the wipers
  12. #12 Re: Alternative for remote wire?
    Quote Originally Posted by barnettimpala View Post
    funny you say that, i used the wipers too.
    some amps need a odd signal sent, and i did see some kind of converter to fake the amp out so it thinks the remote turn on is from a stereo. most i guess just need 12 volts to wake it up.
  13. #13 Re: Alternative for remote wire?
    Yoga city
    yup most just need a 12.xxvolt signal. Some are wierd and want the same as the amp is recieving on the main power.
  14. #14 Re: Alternative for remote wire?
    Feb 2013
    Los Angeles
    I did what you said and it worked. Theres still a pop from them turning off, but its not that bad its a pretty soft pop so it's not a problem. Thanks for the help guys
  1. Amp Remote Wire
    By Xorbex in forum Audio, Security & Visual Electronics
    Last Post: 06-26-2010, 06:10 PM
  2. Need to know remote wire color
    By ljj in forum General Tech Discussion
    Last Post: 05-13-2010, 08:13 PM
  3. blue remote wire
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 08-26-2009, 11:30 PM
  4. amp remote wire question
    By chrissbee77 in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 11:44 PM
  5. Wiring Remote Wire help!
    By adrenaline54 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 10:49 AM
