Thread: New stereo install for 2002 GTP with Bose
Results 1 to 20 of 38
  1. #1 Re: New stereo install for 2002 GTP with Bose
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    Ended up installing the Kenwood KDC-BT852HD with Bluetooth streaming which by the way works great. The stereo sounds great with the Bose system and I don't think I am going to get a sub because the bass is plenty for me. I also like the hands free talking on my cell and I installed the microphone on the sun visor. I will have to get another face plate later because it sticks out about a inch. The reason I used the one is because it came with the stereo along with the harness. The Axxess ASWC-1 works great and had no problems connecting and it learned everything on the stereo and the steering wheel. The face plate, I am going to get it from www.humount.com which has one that lights up and it is a flush mount. By the way, when I wired the steering wheel adaptor it mentioned a resistor which I did not have, it programmed without it.
  2. #2 Re: New stereo install for 2002 GTP with Bose
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Quote Originally Posted by smitz327 View Post
    Nice to hear that the ASWC-1 works great. What wiring harness did you use to interface your aftermarket stereo with the Bose system?
  3. #3 Re: New stereo install for 2002 GTP with Bose
    Oct 2012
    Illinois
    Here is a link to the wiring harness, if you want to use the Bose amp with the system, just take the pink from the cars 4 wire plug that goes to the factory stereo and run it to the remote turn on the new harness from the car stereo. I soldered all my connections Scosche GM02B 1988 2005 Select Buick Pontiac Car Stereo Wiring Harness | eBay I got mine from Sonic Electronix off of eBay and you can get the wiring harness for free with stereo purchase
  4. #4 Re: New stereo install for 2002 GTP with Bose
    Mar 2013
    Manitoba, Canada
    Looks like a nice clean install. What bracket system did you use to mount the head unit?
  1. 01 GTP with bose and OnStar replace stereo without expensive wiring harness
    By Draco in forum Audio, Security & Visual Electronics
    Last Post: 03-10-2013, 12:05 PM
  2. Stock Bose Stereo Replacement
    By jeepers in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2011, 05:19 PM
  3. need help on how to put amp and subs in along with a bose stereo
    By rh5385 in forum Audio, Security & Visual Electronics
    Last Post: 09-06-2009, 12:15 PM
  4. Bose stereo problem
    By jiggar1964 in forum Audio, Security & Visual Electronics
    Last Post: 11-21-2008, 05:02 PM
