Thread: Amp suggestions
Results 1 to 16 of 16
  1. #1 Amp suggestions
    GT Level Member GrandprixGT01's Avatar
    Nov 2011
    Keswick, Ontario
    I recently just bought 2 12" infinity subs off my friend and was wondering what would be the best amp to get for these subwoofers. I believe they are 500w. No clue on where to begin.
    2003 GT: Wizzair CAI, Flipped Dog Bones, MagnaFlow Mufflers, SE Exhaust Tips
  2. #2 Re: Amp suggestions
    SE Level Member Mellsthatguy's Avatar
    Dec 2012
    Michigan
    You need to find a amp that is at least 500 x 2 or you can get an mono amp thats like 1500 and really pound the speakers
  3. #3 Re: Amp suggestions
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    kicker amp
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  4. #4 Re: Amp suggestions
    Yoga city
    Well for starters, when buying an amp don't look at the max wattage. It's just a gimmick and mos amps don't do rated. Look at the rms wattage to evenly match speakers to amp. I would also think about if you want sound quality or spl. Look for some amps and post back. Remember your electrical will benefit from a big three upgrade. Electrical for the amp needs to be on par or you will also lose wattage along the way.
  5. #5 Re: Amp suggestions
    Northeast Ohio
    i agree you want to know what your looking for and what is the OHM on the subs as if they are dual 4s you can run at 4 ohm or 1ohm do not cheap out on a amp dont buy the american bass or five star or lanzar or boss none of that crap do the research and a mono is the way to go...IMO....so be honest for the money the alpine mrp-m1000 is a great amp its now the newest and not the sleanest but it does handle well makes good power and isnt crap. As stated before dont get into the max watt outputs because then crap brand will brag 4000watts but that bench tested with like 24v being pused to it when the best youll give it is 14.4v with the alt running
  6. #6 Re: Amp suggestions
    House springs missouri
    You need to look the rms wattage on the subs and amp and make sure you match the impeidance like if you have 2 4 ohm subs you can wire them togeather for 2 ohms and get a 2 ohm mono block amp
  7. #7 Re: Amp suggestions
    Sep 2012
    bridgeport,NY
    best combo is kicker cvr 12s with sony explode 1200 watt blows windows out and cops hate em
  8. #8 Re: Amp suggestions
    GTP Level Member
    springfield IL
    Get a mmats amp. Big power and ez on electrical
  9. #9 Re: Amp suggestions
    Sep 2011
    Arkansas
    Quote Originally Posted by 06PONTGP View Post
    Ehh? Surely the VFL series isn't "cheaping out".... OP... any amp will work honestly. As long as you set it up correctly, even a Legacy amp will make noise lol. What is your budget? The first recommendation that comes to mind is a Crescendo BC2000D... not expensive, and the headroom will allow you flexibility, seeing as how nobody knows what your subs coils are, as 06 pointed out.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  10. #10 Re: Amp suggestions
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    GT Level Member maverickdog8's Avatar
    Bettendorf, Iowa
    As stated above the first amp that comes to mind is the crescendo bc200d then the audioque 2200d. Both very solid amps. I've ran them both in the past and I would again.
    If you want to go a little cheaper you can always check the car audio forums for one of those used.
  12. #12 Re: Amp suggestions
    Yoga city
    who are you? lol no pun intended. but you hang out over on caco or ca? seem knowlegable in the audio field. Mention crescendo or audioque here is kinda foriegn it seems here. ME i knows what your talking bout lol
    Quote Originally Posted by maverickdog8 View Post
    Bettendorf, Iowa
    Didn't we already go over who I am? The one with the walled gp. I posted up a response to your question with both build logs lol.
    Bettendorf, Iowa
    Quote Originally Posted by JTeske88 View Post
    Post #118 of the "gonna upgrade my subwoofer setup" thread. Lol
  15. #15 Re: Amp suggestions
    Yoga city
    well i dont care about car domain lol
    Bettendorf, Iowa
    That one wasn't car domain. That was my 2 entire build logs for my last 2 years walls.
  1. Looking for suggestions
    By Onos in forum Canada
    Last Post: 04-17-2011, 06:05 PM
  2. Suggestions?
    By astros2900 in forum Visual/Body Modifications
    Last Post: 03-20-2011, 10:38 AM
  3. cam suggestions?
    By 2000gprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-20-2009, 12:39 PM
  4. would like some suggestions...
    By Ramondo411 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2009, 04:27 PM
  5. Thanks. Any suggestions?????
    By lambokit in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 01:26 PM
